Need help keeping the sailors together - Forno Bravo Forum: The Wood-Fired Oven Community
Hello,
See more
See less
  • Need help keeping the sailors together
    Ok, so I've cut the 1/2 bricks for the first couple of courses; using sailors (soldiers laying down). I've run into a problem.
    I've made my homebrew 3:1:1:1 and the consistency seems great. It helps that the weather is in the 70s. I've wet my bricks (dipped in water for a few minutes) and then drain for a couple of minutes. Thought everything was going well. Then comes the time to put the mortar to the bricks. I start at the back center. Put brick against indispensable tool, put brick into position - yeah - this seems easy enough. Get next brick, slap some homebrew on the side; shave the extra off the top and bottom, slide corner next to first brick with positioning assistance of I-tool. Two down - this is going to be easy.
    Or at least that's what I thought.
    Third brick same process, but as I slide the brick against brick two, the assembly of three bricks moves/slides -oops. Grab first brick in left hand and third in right and slide back in to position.
    Fourth brick - wind up with a small crack between brick 2 and mortar. Tried to squeeze it back together. Will this still be a strong joint? Probably doesn't matter on sailor course, but I figure it will happen again on later courses. Should I be taking it apart and redoing it?
    It also happened at other joints as I added more sailors.
    It took me an hour to do the first half of the first course. I'm sure I'll get more adept at it, but want don't want to build inherently weak interfaces.
    Any good videos out there of the bricks being mortared and positioned?
    Thanks for your help!
    Jeff
    Jeff
    My 42-inch build
    Re: Need help keeping the sailors together
    Quit soaking the brick. Unless it is 90 degrees plus and windy it is not needed or desirable. The mortar should grab within seconds.
      Any bricks that move after initial lay should be cleaned and relaid.
        Slow down, it took me over 6 hours to do a course..
        I would continue to soak the brick.. i find the grab is stronger once the mortar has dried a little more.... if the brick is dry it sucks the water from the mortar and doesnt take hold.
          A Sailor is a brick laid with the bed face showing when the brick is standing up, the way the bricks are laid in a dome is a header course.
          And I wouldnt wet them, there is no need, all you will do is make the grab take longer, hence your problem.
            Are you showing mortar between the bricks, on the inside?
            The bricks should be as like the base as possible, ie laid touching without mortar. There are several mortar mixes, the best is the grainey high temperature refectory mix which comes in a bag, just add water. a cheaper compromise is a lime mixed with clay, but if there is portland cement in there you will probably find it crumbling into your pizzas
