Fine perlite verse loose fill for perl-crete mix? - Forno Bravo Forum: The Wood-Fired Oven Community
See more
See less
  • Fine perlite verse loose fill for perl-crete mix?
    I am looking to make the insulation under the bed of my oven out of perl-crete (refractory cement and perlite). I happen to have some of the industrial concrete perlite mix (ryolex) but its the fairly fine grade....(like fake plastic snow--like panko bread crums or slightly smaller)--
    Can I use this or should I use a more granulated size(similar to horticultural grade perlite/vermiculate)?
    Ive read that ratio of 5:1 perlite:cement is workable. ANy thoughts?
