Limestone key way for vent arch? - Forno Bravo Forum: The Wood-Fired Oven Community
Hello,
See more
See less
  • Limestone key way for vent arch?
    The back of this stone will be a part of the throat of the flue will it get to hot I understand 840'c it starts to break down
    Re: Limestone key way for vent arch?
    The vent probably won't ever exceed 500 C.
      You sure about that? The gasses coming out of my oven are pretty damn hot. I have never measured it, but it has to be close to the dome temp which exceeds my laser's ability (950 F plus). Why wouldn't it be, that's where it's coming from. It's most likely going to work but I always go to the edge, then step back a few...
      Edit... I read the numbers too fast, Ed mentioned 840 but I ran with the 500 - huge difference between the two.
        My IR thermometer reads to 2470 degrees F. The highest temps I've ever recorded in my dome were just under 1200 degrees. 840 C is equal to 1544 F.
        I doubt you'd get that hot in the vent but I don't know for sure.
        Bill
