Rooker - what was old is now new - Forno Bravo Forum: The Wood-Fired Oven Community
Hello,
See more
See less
  • Rooker - what was old is now new
    I found a picture of an ash and coal rake from an 18th century technical encyclopedia from France Circa 1750.
    They had a plate that showed a Baker's Rooker.
    So I adapted the design and materials and came up with the items shown in the pics attached. I had enough steel to make two. One long for reaching way back and one for up front work and scraping into a dust pan.
    Material:
    1 each 1 1/4 in X 1/8 in X 8 feet steel strap
    1 each 1x1 x 36 in hardwood dowel
    2 each -1/4 x 1 in bolt with nut and washer
    Overall it is 54 inches
    Re: Rooker - what was old is now new
    Some things you just can't improve on. Nicely done!
      This is a plate from a 1730's encyclopedia from France. Different equipment used in a bake shop. I also posted this on the fire starting thread.
        Thanks for the post. I can see where it would work. I'll be trying one out for myself, real soon .
        joe watson
        My Picasa Web Album
          Is spring steel the same as strap steel? I would be interested in fabricating these also.
          jon
          jon
            jon
            I used flat weldable steel, not spring steel. You should be able to pick it up at any metal retailer or hardware store.
            Did the pics from the 18th century help?
              I have some "mild steel" stock that would be easy to work with. After your original post, I had tried to Google "French oven tools", "rooker" etc. But, could not find it. The pic form the 18th century encyclopedia is golden .
              Thanks again,
              joe watson
              My Picasa Web Album
                Try this video on YouTube. It shows a rooker in action.
                Baked Beans - 18th Century Cooking Series at Jas Townsend and Son - YouTube
                  Yes, this helps a lot. I will be looking into this further once the weather warms up here. I definitely need a tool which can satisfy these needs. Thanks for the info on these rookers!!!
                  jon
                  jon
                    Thank's Michael,
                    This link that you pm'd did show a lot more of the rooker. It will definately be in my line up for the "first team" of tools .
                    Edit: Jas Townsend is a little deep for me on his historical reinactments and such but, he has a lot of great WFO videos and some very interesting history tied to his recipes!
                    Thank's again,
                    Joe
                    joe watson
                    My Picasa Web Album
                      Navyintel,
                      I finally got around to throwing one together this morning.
                      It is a little wider bladed than usual. I went out to my cold and presumably "clean" oven to try it out. I easily raked out another 5 or 6 tablespoons of ash hiding in the corners. The shape of these things make it much easier to rake the very back. The hoe I was using did not get to that area real well. It is also much easier to rake the blind spots just the sides of the arch. The rooker is a great little tool and, very easy to build.
                      Thanks for the idea .
                      joe watson
                      My Picasa Web Album
                        G'day Gulf
                        That looks the part. I'm warming to this tool more and more as time goes on.
                        I recon if I can find some steel to suit I'm going to make myself one. My oven entrance protrudes into the oven floor and I recon there's ash in those corners from the first fire!
                        I've put away some 1 1/4 in hard wood stock away for the handle already. It will plane and sand up well.
                          This rooker seems to be an interesting tool, and getting some good reports. I have been using this curved bladed tool to move the fire around the oven and remove ash and coals etc. It is made of aluminium sheet and is a little less than 3" across the blade. It works both left and right handed and I use it to both push and drag ash and coals. As you can see it is a front line tool.
                          Cheers ......... Steve
                            Gulf's tool looks great. The design has the final metal at 90 degrees and straight, not curved. This makes 100% of the coals in contact with the tool regardless of the handel angle. Good job.
                            Michael
                              G'day Steve
                              How thick is that blade? I have some aluminum which is 2.5 mm thick that might make a good rooker if it stiff enough. I like aluminium ...less likely to wear an chip the oven
