How to fill the holes in cinder blocks - Forno Bravo Forum: The Wood-Fired Oven Community
Hello,
See more
See less
  • How to fill the holes in cinder blocks
    Does anybody have any brilliant ideas on how to fill the holes in the cinder block so the cement doesn't just fall through before pouring the top?
    Also, has anyone used ceramic fibre (or fire) board under the fire brick for
    extra insulation?
    I'd appreciate any help.
    Cheers,
    Tom
    Re: How to fill the holes in cinder blocks
    Those of us that used bagged concrete just wadded up the bags and stuffed it into the holes. Could probably use newspaper as well. You should fill every few cores solid to lock in the block, every core is not necessary.
    extra insulation?
    Not sure by what you mean "extra insulation" 2 inch board should be used at a minimum.
