which vermiculite to use - Forno Bravo Forum: The Wood-Fired Oven Community
Hello,
See more
See less
  • which vermiculite to use
    The only vermiculite I have found in my area is a fine sand like prouduct used to insulate concrete block. Is this ok to use for the insulating pad and cap.
    Thanks Larry
    Re: which vermiculite to use should be uncoated
    Thanks Larry
    (M) If you have found a Vermiculite that has been coated for easy pouring into the cores of your cement block, that is not what is recommended for insulation. Coated Vermiculite, or Perlite will not readily absorb the water necessary for proper hydration of your "Perlcrete". If you're mixing an insulating "concrete" get the uncoated common garden - horticultural variety.
    Ciao,
    Marcel
      Thank you this helps a lot.
      Larry
