Refractory Mix Cracking - Forno Bravo Forum: The Wood-Fired Oven Community
Hello,
See more
See less
  • Refractory Mix Cracking
    Hi Can Anyone Tell Me Why ? The Refactory Sila Mix Im Using In Perth W.A
    Is Cracking, Im Weting The Bricks And The Mix Im Making maybe A Little to moist
    Cheers Pat
    Re: Refractory Mix Cracking
    Did you use the premixed refractory mortar? Im building a small scale prototype(cant afford the real one yet, but want to practice with the materials), and here in Salt Lake the premixed product is much easier to get ahold of. It comes mixed VERY wet, and from my experience, wet cements are more likely to crack. More water in the mix means more volume, and when the mix dries(even though it is a chemical reaction, not just drying), water is forced out of the cement, and this means a loss of volume. this causes shrinking.
    I think. Anyone more experienced here wana back me up?
      Cheers for your input!
      I,m not using a premix with water, rather a dry - premix. But what I've since learned in the forums , The're suggesting not to use an air-dry, mortar, for exactly the reasons I'm encountering !
      Pat
        All refractory mortars I know of will shrink somewhat. If you are spanning a joint of more than 1/4 inch or so expect cracks. If you want to span a larger joint - extend the mortar with a sharp sand (mortar sand or silica sand). For 1/2 inch span, go with a 1 to 1 ratio, 1 inch span try a 3 sand to 1 mortar mix ratio. If you have tapered joints, try having two mortars - "neat" for the tight part and "extended" for the wider part.
          Cheers for the info Neil, ended up going with the fireclay , lime,sand and cement mix recomended by Forno Bravo, and now have completed the oven. Now been sitting for two weeks and about to start firing. Will post photo's from start to finish in the next week.
          Pat
            Hi Mark here from NSW Australia. I hope this is a suitable place to ask this question but...
            I've gotten hold of some high temperature raku clay and intend to mix it with lime and sand for a dome mortar - what do you guys reckon??
            ta
              Hi Pat;
              Where did you find fire clay in Perth? And did it hold up OK once fired?
              I'm in the process of finding materials at the moment, so an advice for stuff in Perth greatly appreciated.
                Hi Adrian,
                There's a pottery shop in Occonor. I cant remember the name right now, should be in the yellow pages under pottery supplies. There's also a perlite manufactorer in Jandacot. Fireclay has held up well well no problems as yet!If You need further help contact me at pattydazzler@hotmail.com
                Goodluck
                Pat
                  Hi all,
                  well here we have a thread with a few newbies from this wonderful land of ours. Great to see the Australian increasing the forum numbers.
                  Welcome to Westozchoppers (Pat), Nokka and Adrian.
                  The poor mans version for the mortar works fine and I haven't had any problems with mine over the 18 month build time.
                  Post some pics so we can all share your joys.
                  Cheers.
                  Neillís Pompeiii #1
                  Neillís kitchen underway
                    Thanks Pat for the pottery shop suggestions. I live North of the river, and found that Stilletano's Home Hardware in Malaga stock Fondue cement. It's $47 for a 20kg bag, but it would probably cost me that much in fuel to drive to Oconner!
                    They can also get rockwool insulation for about $50 / m2.
                    I've found the perlite place in the yellow pages and will give them a call to get a price.
                      my old man told me that he saw fireclay for sale in bunnings the otherday so maybe check out there or ask them and they can get it in
                      Real men cook with fire
                      My Oven and Fireplace Build
                        Which store? I've asked at Inglewood, Morley and Balcatta for ref. cement, fire clay and rock wool. Got blank stares or confused information at all three stores, and couldn't get any of these.
                          Hi, I found the refactory cement I used of the shelf, would crack here in W.A.
                          I tried mixing it wet and dry and soaking the bricks, the so called air dryed mix I wouil stay away from and suggest using Forno Bravos recipe,fire clay,white sand and lime.
                          Pat
                            Thanks for the info
                            It sounds like if white washed sand works so would plasterers sand
                            Brickies sand must have too much loam
                            Pat
                              Ask around for fire blanket, this is often rockwool
