this is all super helpful! I have already set the walls with the heat set stuff but I will do the arch with home brew. thanks for the heads up on the cracking, I wont freak out so bad when I see that happen.
i guess you didn't have any cracking
Edit:
did you use silica sand or play sand?Last edited by Gulf; 12-05-2018, 05:19 PM.
Joe, did you use silica sand or play sand? I want the joints pretty tight. I just looked at your build and its really nice! i guess you didn't have any cracking?
+1 on Russell's answer. I would just go with the homebrew and skip the heat set.
- 1 like
Thanks for the information! I remember stumbling upon your build awhile back. Man, that is sharp! I love the little details like the engraved sun in the top of the dome. love the copper.
it is heat set! is the concern that they float or move after the arch support is removed? will the back fill mortar hold enough until it is heat cured?
You can back fill with what we call "Home Brew" 3 sand, 1 lime, 1 portland, 1 fire clay. This can also be used to do the entire dome if you wish. Confirm the refractory mortar is air set not heat set before you proceed..
dome mortar
So, I have some pre-mixed refractory mortar. But the joints cant exceed 1/8th inch(3mm). my plan was to set the dome brick with this stuff then fill the back of the dome, where the gap is more like 1/2 inch, with type S and Fireclay mix in a grout bag.
Does anyone see a problem with that? I saw that Stonylake might have done this but it doesnt look like they are active on the site.Tags: None
