Tile saw for cutting brick
  • #16
    Re: Tile saw for cutting brick
    Hmmm i need one too ill look into this one.
    • #17
      A new HF opened up last week in Worcester, MA. I picked up the HF tile/brick saw for $180 (sale price of $199.99 minus 10% grand opening discount). The grand opening flyer coupon is good through July 1.
      • #18
        but what about in the uk what would you use any thoughts? cheap
        • #19
          And what about in Australia? This is what Bunnings have to offer: Looks like it might be the type that gets you messy with every cut?
          450W RYOBI? Wet Tile Cutting Saw (180mm) (ETC450) - Bunnings Warehouse
          JT
          Willetton, Perth
          Western Australia
          My build: http://woodfiredovenperth.blogspot.com.au/
          • #20
            That was the type I used. It did get a little bit wet, and I did have to cut each brick twice... cut one side, flip it over, cut the other; but it was certainly better than nothing, and since I had borrowed the tool from a friend the price was right. I had to temporarily modify the blade guard, which normally keeps the water from flying. If you remove it to allow the brick to pass, water sprays everywhere; so I remounted the guard on a flange that would allow the brick to fit. It kept most of the water in place.
            If you want to do precise cuts, the other type would be better; but for me , this worked fine. If I were doing more than one oven, I would definitely invest in another saw, but for a one-off project, it was all I needed.
            -jamie
            My oven build is finally complete!
            • #21
              Give a rest with spam will you.
              • #22
                Hi there
                When you say you removed the blade guard, did you mean that you also removed the mounting bracket to which the guard is fitted? I wouldn't mind seeing how you mounted a flange that still allows the brick to pass - having trouble envisaging a solution, as I am having to do four cuts to get a brick in half right now.
                JT
                JT
                Willetton, Perth
                Western Australia
                • #23
                  Originally posted by jab49 View Post
                  Hi there
                  JT
                  I don't know if I have any pictures of the mount... I'll look through my files and get back to you. I can say that yes, I did remove the mounting bracket and replaced it with one I had rigged which was long enough to reach over the height of a brick. I used a piece of thin sheet steel about 3/4" wide and 4" long, with holes drilled at each end for the mounting screws. It was crude but simple and effective.
                  -jamie
