Husky 7 Bearing replacement - Forno Bravo Forum: The Wood-Fired Oven Community
Hello,
See more
See less
  • Husky 7 Bearing replacement
    Hi
    I just bought a used HD husky THD950 wetsaw. It?s in good working condition, almost new, but I anticipate that I will kill it somewhere along the way. I will be using it for at least 3 projects: patio pavers, WFO, and retiling of at least one bathroom in that order. Actually the patio and the WFO will be at the same time. I did a little research and I have a link to a tile forum where one of the posters has figured out how to replace the bearings on the saw. This is a major wear component besides the blade and not that expensive to replace if you know how. Here is the link:
    Ceramic Tile Advice Forums - John Bridge Ceramic Tile - Husky Wet Tile Saw
    Look for the post by antman about ? of the way down. Pretty good instructions. I hope it helps you guys.
    Regards
    Larry
    Re: Husky 7 Bearing replacement
    Looks like my old MK 470....was a great saw (cut hundreds of tile on many projects over many years)......sorry to say, about 12 firebricks killed it (bearings were going bad prior to the firebricks). Bought the 10" HF saw....a 10" saw makes a world of difference in cutting bricks.
    RT
      MK's are work horse and depending on how you killed it you can probably fix it. My Porter -Cable 15 yr old router was squeeling like a banshee. just needed new bearings.
      je
