Spaces in my oven floor - Forno Bravo Forum: The Wood-Fired Oven Community
Hello,
See more
See less
  • Spaces in my oven floor
    I did a really bad job of laying my oven floor. I got some of the fire clay and sand mix between my bricks and have several with spaces between them...
    What can I do to smooth my oven floor out?
    Re: Spaces in my oven floor
    I would think that you could fill it with fire clay
      If you are talking about vertical - you can use a belt sander. Buy the most abrasive and cheapest ones you can find. If you mean gaps between the floor bricks - no sweat. They will be filled with ash. All you need is a floor that won't catch your peel.
      Les...
        Don't worry about it,
        as Les said, they just fill up with ash.
        You won't even notice them.
        My 2nd Build:
        Is here
          I agree fill the spaces with ash, anything else will pop out as it does't expand and contract at the same rate as the fire brick.
            i agree also..don't fill in spaces with anything but the ash....i had to grind a few edges to smooth out joints edges so the peel will slide smoothly
            Can't wait for the next one!
