Infrared Thermometers-Questions - Forno Bravo Forum: The Wood-Fired Oven Community
Hello,
See more
See less
  • Infrared Thermometers-Questions
    Hi everyone. Our oven dome is finished YA--and we've been lighting progressively larger fires--but no fires hot enough to burn the soot off the dome ceiling. We didn't install thermocouples and I'm looking at infrared thermometers--and I have some questions. The one available from the FB site registers to 932 degrees--is that enough? Can't some fires go hotter? Also how close must you be to register a temp accurately. So of the others I've been looking at have a ratio number I've seen 12:1 and 8:1--does this relate to distance? What brand is the FB one and do I need to be concerned with accuracy amongst different brands? How many temp readings should I take and will the temps vary much in different parts of the dome? Thanks for the help.
    Re: Infrared Thermometers-Questions
    Gidget, I'm no expert, but I have an IR thermometer and I'll take a crack at these:
    Yes, I would say so. Once you get over 900, you know it's HOT, plenty hot to cook anything. Fires do go hotter (in the 1200 deg. range), but is it necessary to know that? Cooking is done on surfaces that measure 900 and lower.
    Yep, it's the field of view. The farther you stand away from the spot you want to measure, the larger the actual area is that the IR beam is measuring. Shouldn't be of much concern in a wood-fired oven, since you'll be standing at the archway and aiming at the floor & dome.
    Not sure about the brand, but I haven't read any reports of inaccurate readings with any brands. Like all FB products, their thermometer is definitely tried-and-true.
    The temps will vary considerably for a while, especially when comparing the dome to the floor. Eventually the heat saturates everything and evens out. Just take a couple of measurements around the dome and floor every now and then after the soot cooks off. When everything is 800-900, you know you're ready for action.
    Daren
    Picasa web album
    Oven-building thread
      Thanks Daren !
        I got the one that FB sells and it works great
          I heard, or read, that there are IR Thermometers available that will also take thermocouple inputs. I have not yet been able to locate one.
          Does the unit offered by Forno Bravo accept thermocouple inputs and is there a spec sheet available? Can anybody point be towards thermocouple compatible IR thermometers please?
          Thanks,
          Travis
          TravisNTexas
            Try this link:
            Handheld Infrared Thermometers
            note you can pick up an equivalent unit to the first one listed ($49) at Harbor Freight on sale for $29.99 (HarbourFreight.com item # 96451-2AAB) That's the unit I have and so far it has worked well.
            Wiley
              Mastercool has some as well. Click here for one example.
              And Omega Engineering has some too.
              The only drawback of these (speaking from experience), is that if you have more than one thermocouple, you have to constantly plug and unplug the wires from the IR gun to take readings. If you can afford a dedicated thermocouple reader, I would consider it. The combo IR gun/thermocouple reader works fine, but it can be a hassle. Just my $0.02.
              Picasa web album
                I was thinking about as switch box with just a single set of leads that would hook up to the IR and allow selection of one of several thermocouples at a time.
                From what I have read, it sounds like folks really seem to only use their thermocouples for a short while when curing and then learning to use the ovens.
                Thanks all,
                Travis
                TravisNTexas
                  I do a bit more roasting and baking than anything else, and so I use my thermocouples quite a bit. I have three in the floor and one in the dome. Its a lot easier to look out of my window and know the temperature, than having to go out with the gun, take the door off and take a reading. The only time I use my gun is during pizza making. It seems to give a more accurate reading of the floor surface.
                  Oven Progress
                  Bread Photos
                  Oven Stand Thread
