Aluminum foil - Forno Bravo Forum: The Wood-Fired Oven Community
See more
See less
Aluminum foil
  • Aluminum foil
    I was told to use aluminum foil for covering gaps between bricks!
    Any input is greatly appreciated!
    Re: Aluminum foil
    Aluminum foil and mortar is not a good mix, the mortar will rot out the foil, so any supposed advantages, like heat reflection or vapor barrier, won't materialize.
    I used a sheet of foil between my inner and decorative outer arch as a slip plane. It didn't matter if it rotted out, because I only wanted the oven not to be adhered to the masonry exterior.
      Re: Aluminum foil
      What about using the foil after the mortar has dryed and cured?
        Re: Aluminum foil
        reflective barriers only work well when there is an airspace on the hot side of the reflective barrier. If they are in contact with the hot mass they conduct the heat and radiate it more quickly away from the oven.
