dome height - Forno Bravo Forum: The Wood-Fired Oven Community
See more
See less
dome height
  • dome height
    hello, i am trying to figure out some information, on the pompeii plans for a 42" oven, it says that the inside height is 15.5" , i read on the forum that someone has a height of 19", is this internal or overall height? thanks, marco
    Re: dome height
    Are you talking about the dome height? A true radius will put your 42 inch oven at 21 (internal). There are some that built another version that flattens out at the top (can't recall the name of it). You may be confusing the dimension with the entry height.
      Re: dome height
      Marco, I've read that most 42" ovens are 21" at most, and many are 19-20". It seems many keep the 21" diameter an there is no harm in bringing it down an inch or 2 near the top as you are finishing. I'm shooting for 19-20" wherever it ends up.
      My Oven Costs Spreadsheet
      My Oven Thread
        Re: dome height
        Hi. We are building a 42 incher with a 21 inch dome height. I expect it to sag a bit, hopefully not much, when we fire it up as we are using an unusual mortar, a mix of local soil (clay/sand) and a sugar cane derivitive. When heated the mortar turns to a ceramic like material, we are told, and the end result is a good surface. I assumed dome height to be rather important for best results, but understand that under 21" is better than over.
          Re: dome height
          I think what you might be referring to is what some call "neapolitan" versus "tuscan" oven...the neapolitan apparently has a flatter shape whereas the tuscan is more round...I don't believe that there would be a tremendous amount of difference in the cooking characteristics of the two...for a newcomer to oven building the more gentle curve of the tuscan, whose dome might be called semicircular, would be easier to build...
            Re: dome height
            thanks to all, yes i was a little confused about the internal height, and especially on the first course on the dome, some start with a 9" and some with half brick, wich is better ?
            thanks, marco
              Re: dome height
              I think, though I might be wrong, the plans call for half-bricks for a Tuscan style or a vertically standing whole brick (side facing in) for a Neopolitan oven. I recommend you do some more research on this site, so that you are certain as to the type of oven you want, and what you want it to do. Once you're set on that, then your question becomes moot.
                Re: dome height
                Also look closely of the photos of other builds, as some have built the dome on top of the floor and others have built the dome around the outside of the floor. If you use a full brick first course, but are putting it around the outside, internally, it's the same as just using a half-brick soldier course (if that makes sense).
                  Re: dome height
                  thanks to all, i have a better understanding of what i got to plan, i will make my choice and i will post it .ciao.
                    Re: dome height
                    hello, yes that is what i was referring to, now i get it, thanks a lot
