web analytics
Sealing Ingloo around Dura-Tech Chimney? - Forno Bravo Forum: The Wood-Fired Oven Community
Dome Installation Video - Casa / Premio / Modena
For many of you who bought a modular oven, you may have asked how we put the domes together when we build them. For those of you considering one of our ovens, we shot a video to make your install easier.
Check it out on our You Tube Channel.
If the link doesn't work, simply go to You Tube and type Forno Bravo Channel. The video title is How to Set your Forno Bravo Oven Dome Pieces.
Thanks for participating in our Forum. We will have more video content available soon.
  • jrparks
    started a topic Sealing Ingloo around Dura-Tech Chimney?
    I planning on wrapping the perlite concrete around the Dura Tech chimney pipe. How is the best way to seal joint? I will cover the oven with a stucco product and sealant. This is a pacific northwest oven and rain is always in the forecast!!! I have storm collar for the chimney pipe but think will look bad. Any techniques or advice is welcome.
    The space between the brick arches in front will be filled with perlite concrete and the entire front will have a stone veneer.
  • ThisOldGarageNJ
    Re: Sealing Ingloo around Dura-Tech Chimney?
    hi jr, i would just seal with some heat stop. or whatever mixture of fire mortar you are using. the joint will be covered and surrounded in perlite wont it ? As far as the storm cap, why dont you put a cap you like and just make a cover for when you wont be using the oven for extended periods... (which wont be often believe me) Good luck..
    PS your ovens looking great keep up the good work
