A plug for HFTools - Forno Bravo Forum: The Wood-Fired Oven Community
See more
See less
A plug for HFTools
  • A plug for HFTools
    I bought my wetsaw from Harbor Freight Tools in August of 2007. With the normal cost I plunked down the extra $30 for the extended warranty. I used if for my entire build cutting both angles and bevels on each brick and then lent it to a fellow fornobravoer for his entire build. Last weekend while doing some fascade work the little pump (probably a $7.00 item) started making noises like it was on its last leg. I called HFT and asked if they would replace the pump. The manager insisted that rather than exchange the pump that I bring the saw back for a full replacement. Nice!
