HF tile/brick saw, pump in external reservoir - Forno Bravo Forum: The Wood-Fired Oven Community
Hello,
See more
See less
  • HF tile/brick saw, pump in external reservoir
    I've read the suggestion of putting the pump in an external bucket to keep it from clogging up with brick dust/clay. I'm confused how the water system remains "closed" in this configuration. All the water is transferred from the external bucket to the saw's water-tray, but then never back to the bucket again. How does this work?
    Thanks.
    Re: HF tile/brick saw, pump in external reservoir
    Hey Keb,
    Adding the bucket your just using fresh water, not a closed system anymore.... you refill the 5 gal bucket with fresh water as needed and the tile saw just overflows/drains onto the ground..
    Mark
      So don't use it in the basement then. I'll come up with something, maybe notch the tray so it overflows at a single point, then put a bucket under it on the ground.
      Whatever...just wondering how it works. I have a picture now.
      Thanks.
        You can have a steady stream of new water going into the bucket with a hose, if you want to....
        Picasa web album
        Oven-building thread
          That's how I did mine, unless I was just doing a couple quick cuts. Worked really well.
            I kept the plug in the tray so that it captured all of the saw residue. I just scooped it out periodically. I now have a five gallon bucket full of fire clay to use when I build another one.
            Joe
            Joe
              A wet saw indoors gets a bit messy, even if you recirculate the water in the tray you still have to contend with the spray going all over. The closest I have come to indoor use is my attached garage (cars pulled out in the driveway of course).
              RT
                If it doesn't have a plug, tilt it back and to the side just a little so that the water runs out of the corner into the bucket. The pumps don't really clog anyway so long as you freshen the water occasionally.
                As an FYI, I save all of the brick dust for a gauging and colorant material. Who can guess what this is:
                  Yeah, it has a plug, I forgot. I only just put it together last night. I haven't even turned it on yet.
                  Thanks.
                    Polar region of Mars?
                    George
                    My 34" WFO build
                      brickdust ??
                        Close enough, limestone dust.
                          did you take that pic with your microscope ??
                            No that is a couple of pounds of dust, a couple of hours of sawing four sides of thin veneer limestone. I put a piece of 1/4" hardi backer behind the blade to collect it (and reduce the mess).
