Pool Crete - Forno Bravo Forum: The Wood-Fired Oven Community
See more
See less
Pool Crete
  • Pool Crete
    Can i use pre-mixed pool crete in place of mixing vermiculite and portland cement?
    Re: Pool Crete
    You can, but I don't think there's any real advantage to it in these tiny quantities.
    That said, the guy I bought my perlite from now sells a concrete mix for pretty much the same price:
      Re: Pool Crete
      I've worked with this and it seems to have a bit higher cement content than what I've seen recommended on this site.
      It mixed and hardended well.
      I bought it at a pool supply shop expecting loose vermiculite, but found it was a mix later.
      I used it as a loosely arranged second layer over top of ceramic blanket around the base of my dome.
      My oven progress -
