Quikrete Masonry Waterproofer - Forno Bravo Forum: The Wood-Fired Oven Community
Hello,
See more
See less
  • Quikrete Masonry Waterproofer
    I was perusing Quickrete's website and saw this:
    Masonry Waterproofers | QUIKRETE? Coatings
    I wonder if anyone had an opinion of it, especially in contrast to the surface bonding cement? Would/could it be used instead of SBC (over a more basic stucco?) or in combination with SBC (as yet another layer applied over the SBC)?
    Re: Quikrete Masonry Waterproofer
    Keith - Looks like you just went with SBC over your insulation without using the water proofing?
    Also, where did you end up getting your SBC? I've looked around my local HD and Lowes and have not found any. I think you mentioned getting your powdered color at Salmon Bay?
    Thanks!
    Pizza Oven Picture Gallery
      I plan on using SBC as my final stucco coat but without using the fortifier. Both our local Lowes and Orchard Supply Hardware carry SBC but in white only.
      I'll use elastomeric coating, tinted to my color of choosing, as my final coat over the SBC. I'm not sure if this is similar to Quikrete's waterproof coating. Behr elastomeric coating is available at Home Depot.
      George
      George
      My 34" WFO build
        Thanks!
        My SBC doesn't go directly over the insulation. The structure is obviously poured vermicrete (over a three inch layer of InsWool over the brick). The poured vermicrete is walled up within vertical hardibacker and the horizontal surfaces (planter beds) are parged with a Portland/fireclay slurry (fireclay not for thermal properties but just as a very very fine "aggregate", and maybe some sand too, I don't remember). Then, over all of that I did three layers of SBC with acrylic fortifier, the second and third coats being colored with iron oxide powder.
        So, in short, the SBC is never touched the insulation, either the InsWool or the vermicrete.
        But no, I never bothered with any additional waterproofing or sealant. I believe three layers of acrylic SBC will be extremely waterproof. It might be insufficient for submersion (a swimming pool) but for a non-submersed surface I expect it to be fine. My planter beds have plastic under them so while I'm sure moisture will seep under them to some extent they won't simply soak up the damp dirt nonstop.
        Furthermore, so far I haven't seen so much as a thumb print of a watermark inside the oven (and it has been pretty wet recently). It's bone dry.
          Thanks!
          Lowe's doesn't carry it, but ordered it for me upon request. Paid in advance, it arrived at the store within a week. Also ordered the gallon acrylic fortifier. They had the quarts in the store but the gallons were obviously cheaper.
            Thanks for the tip Keith - I was able to order it through my local Lowes as well. Just had to ask at the project desk. Talked with them on Saturday, they ordered it yesterday, and should be ready for pickup on Friday.
            I was also able to order the Quikrete Stucco Base. Probably could have made my own instead, but it was only $6.50 per 80lb bag. The SBC was $15 per 50lb bag.
