How Do You Reheat Pizza?, Tale of Two Flours, Eggplant Pizza - Forno Bravo Forum: The Wood-Fired Oven Community
  • How Do You Reheat Pizza?, Tale of Two Flours, Eggplant Pizza
    Instructionals
    Roasted Seasoned Eggplant Pizza
    A Simple Salami Pizza
    A Second Transformation - How do you re-heat your pizza?
    Guest Columns
    Pizzeria Crawl on Bleecker Part 2
    Pizzeria Crawl on Bleecker Part 3
    A Tale of Two Flours - by Stan Ginsberg
    The Pizza Guy
    Peter's Blog
    Peter's Blog, May 9th, Pure Pizza
    And lots more from Peter!: Peter's Blog
    Re: How Do You Reheat Pizza?, Tale of Two Flours, Eggplant Pizza
    I usually put it in the microwave for about 45 seconds. I wouldn't call it good, but it is definitely edible.
      Using a microwave on FULL will turn your crust to leather, but if you increase the time and reduce the power to around 50%, it is almost as good as straight out of the oven.
      Neillís Pompeiii #1
      Neillís kitchen underway
        Gudday
        I love to put a slice back in the oven first thing in the morning. You could probably do the same in the kitcken.... but its great to head into the garden in the early morning. A bit cold but. Crack the door of the oven open ...big rush of heat in your face.. through the slices in on a tray. And just wait for them to heat. Just you ....a cup of coffee... the early light...the re-heated pizza slices are just a added bonus....
        Regards Dave
          Showing off, Cobblerdave?... Sigh...maybe mine will stay warmer as time goes by. Thanks for the tip re the soot being an indication of dampness!
          Back to the question, I reheat on a pizza pan with holes (so it gets crispy) in the oven at about 350. No microwave, gets too soggy!
          -Shelley
            Make use of a toaster oven. Two cycles of oven if the pizza is instantly from the fridge. If it is in larger amount, heat a foil-lined sheet oven until hot.
              Toaster oven rocks for reheating pizza and maybe what it's best at. I foil line bare rack and use toast feature, in about 3-4 minutes pizzas like new again. I sometimes wrap outer crust in foil to protect it from getting ruined.
              Chris
              Link to my photo album:
                I use the toaster oven too, but a little differently
                Put the pizza on the rack, turn temperature to 500, and the pizza is hot and crispy about when the bell rings to tell me that the oven is at temp
                  For me its heat the plate 1 min microwave
                  Then put the pizza on it 12/15 seconds
                  Its not hot just room temp like a good breakfast pizza should be.
                    Try putting the pizza slices in a skillet on low heat until the cheese starts to melt.In my humble opinion this makes for the best reheated pizza possible. Try it then judge for yourself.
                      I need some more details, pan temp particularly and how the cheese becomes melty with no over head heat?
                      Chris
                        Pan medium temp in between low and high.The cheese on top melts from the heat that came up through the bottom up through the pizza to the top.
                          I never reheat my pizza I prefer leftover pizza cold. I have since I was young, and now at work it means I don't need to be in line for the microwave at lunch time.
                          Randy
                            I put mine in the WFO on a sheet of baking paper. Oven is hot enough next day or two to do the trick.
                            Cheers ......... Steve
