Attempt at Napolitan pizza on a stone - Forno Bravo Forum: The Wood-Fired Oven Community
  • Attempt at Napolitan pizza on a stone
    Hi
    Today I had another try to make Napolitan pizza.
    But this time is the first time I've used a stone, a cordierite.
    I don't post any picture because the result wasn't good.
    Last time my pizza was too dry, then this time I've increased hydration to 65%, maybe too much. I've also used high gluten flour, some semolina, and fresh yeast.
    I kneaded it for 10 minutes, and I left the dough 1 day in the fridge. Then 2 hours out of the fridge.
    I had to use oven paper to spread the pizza and be able to transfer the stone to it because the dough was too liquid.
    I used tomato, mozarella and ham for the topping.
    I had several problems:
    The border of the paper raised, lifting the pizza.
    The borders seemed to be right and I didn't noticed that the middle was burning on its bottom face.
    However the top face of the dough (near the center) was RAW. I don't understand why because the dough was very thin and the pizza is supposed to bake properly on a stone.
    The baking time was around 6 minutes.
    I'm starting to think the dough I like is not the Napolitan one. Whatever I try it doesn't taste as the pizzas I like.
    If I use too little yeast I get a very hard pizza. And I don't mean crispy but hard.
    If I use too much yeast I get something that tastes too much of bread.
    I've alsto tried with few yeast and long time fermentation but I can't get a good pizza.
    Next time I'll try some other recipe with more ingredients (milk, egg yolk...) that disguise yeast flavour or maybe some baking powder or 00 flor instead.
    Re: Attempt at Napolitan pizza on a stone
    What temp was the oven set on?
    I usually put the stone in for about 20 minutes at full blast before I cook a pizza
    At 250 ish (electric fan forced)
    it takes about 11 minutes to cook a pizza in my oven
    I use 00 flour 3 cups to 1 and bit cups water 2 tsp dry yeast
    Knead for 10 ish minutes roll into a ball coat in ev olive oil in a bowl with glad wrap (no eggs or milk)
    24 hours in the fridge.
    It tastes fantastic.
      Hello
      It's an old gas oven, the broiler doesn't work, then I decided to put the stone on the bottom.
      I just put something metallic to have a 1 inch gap between the bottom and the stone and allow the air to flow.
      The oven was set at its highest temperature, 240?C, I guess this should be the average temperature within the oven. The stone was at more than 300?C because it was very close to the flames. My thermometer can't measure values above 300?C.
      I think it was hot enough because it burnt the bottom of the pizza in 7 minutes but I don't understand why the other side was still wet and raw.
      Maybe I used too much water or a flour with too much proteins.
      I still have some of the dough in the fridge, I'll try again tomorrow. It will have been 48h resting. I've added some all purpose flour to the dough in order to lower proteins ratio and dry it.
      Next time I'll try with sourdough instead of fresh yeast.
        Here's your answer:
        Pizza needs heat from below AND above.
