Heard of this method? - Forno Bravo Forum: The Wood-Fired Oven Community
  • Heard of this method?
    Get a ?-inch-thick sheet of steel from a metal fabricator (Search online for a local one), have it cut to the size of your oven shelf and insert it in the rack closest to the broiler. Preheat the oven at its highest temperature for ? hour, then turn on the broiler and slide your pizza onto the metal plate. It should emerge perfectly cooked in 1.5 to 2 minutes.
    Curious if the home user could use this without investing in a pizza stone?
    Re: Heard of this method?
    I assume you meant oven...?
    George
    My 34" WFO build
      A recent thread on this topic. If anyone has done it, they didn't admit it here.
      http://www.fornobravo.com/forum/f28/...ven-15396.html
        I can't see a cost benefit if you are looking for a cheaper option than a stone for your home oven. A 1/4" sheet of steel, cut by a fabricator to fit your oven, could easily cost as much as a stone; unless said fabricator is a close friend. Most shops won't mess with small requests such as this unless the customer is willing to pay dearly. Simply too disruptive to there production. Just the steel cost alone may equal the cost of a stone. I made my first WFO door from an a 18" x 24" piece of 1/4" boiler plate. The cheapest supplier was $19. Figure at least double that cost for a piece large enough for a home oven.
        RT
