Help - I want to build a pizza oven and I'm in the Canberra region
  • #16
    Re: Help - I want to build a pizza oven and I'm in the Canberra region
    How much did it cost you guys all up to build your ovens? rough estimate would be good
    Tim
    • #17
      I guess you would get away with about $1,000.
      Give me a call on 0451470371, we have all you require, in Melbourne, all goods are in stock, and FREE thermometer when you spend $500.
      • #18
        Hi Tim
        I built my oven with Canberra reds, if u like we can meet up and show u the oven. I live in lyneham, let me know
        Trev
        Trevor.williams@y7mail.com
        • #19
          Originally posted by wookiewins View Post
          Hi Tim
          Trev
          Hi Trev, about to start on a build project in the bush in the Southern Highlands and glad to hear about Canberra Reds!! I have been trawling through the various threads, price lists etc trying to work out the parts I'll need. I have some Canberra reds but probably not enough for the full dome and I had been wondering if they would be OK to use. Can they be mixed with fire bricks and if so what would be the best - use the Canberra reds for the lower courses or the top of the dome?
          Many thanks for any input,
          Andrew
          • #20
            Gudday
            I've heard a coupla references to the "Canberra Red".... sounds like a pretty solid brick. There a common from out west in the tablelands up here that weighs more than a firebrick
            If you are using a common brick and put it on the ground give it a good hit with a hammer breaks cleanly ....great...crumbles or breaks into pieces ...forget it.
            If your using some firebrick use in the hearth if you can't a double layer of clay pavers will give you a good amount of thermal mass.
            Above all Insulate above and below
            Regards Dave
            • #21
              Hi Johnny,
              Thanks mate, will probably be easier to find things locally but just in case... how much would i be looking at for for The firebricks, Insulating board and blanket?
              Cheers,
              Tim
              • #22
                Anybody know where to find cheap besser blocks or canberra reds in canberra, $4.20 for the blocks at Bunnings...
                Tim
                • #23
                  Originally posted by mothy View Post
                  Hi Johnny,
                  Cheers,
                  Tim
                  Best give me a call on 0451470371
