Karangi Kitchen 48inch ready to start - Forno Bravo Forum: The Wood-Fired Oven Community
  • Karangi Kitchen 48inch ready to start
    Sorry all content has been removed by the publisher
    Re: Karangi Kitchen 48inch ready to start
    welcome onboard
    Glad to see your still around remember you from JAS post talking about bricks from Dimore.... must be sept/oct sometime...
    my Bros family live in coffs know what the floods can do to the main center bet ya insurance premiums are murder
    keep posting your progress there a great bunch here and will support and help
    regards dave
      I think it would be safe to say now that you fully committed?........even got the " minister of war and finance " on the end of a sledge hammer...I'm impressed
      Regards Dave
        I can see a potential problem raising it's ugly head not too far down the track!
        With a 48" or 1200mm oven planned, there will be quite significant increase in bricks and weight sitting on that slab, especially on the outer edges ----right?
        I personally would have dug a beam footing around the perimeter and put a few extra reinforcing rods in there to take the load.
        All is not lost though, I would use 2 courses of brick for the build-up and fill the void with F62 mesh and vibrated concrete as a 3" vertical slab OR fill your Besser blocks (or as the AS members call them cinder blocks) with concrete for the extra strength that will be needed.
        Cheers.
        Neillís Pompeiii #1
        Neillís kitchen underway
          Good to see that you are addressing the potential problem.
          With your planned improvements, it should stand the test of time.
          Neillís Pompeiii #1
            Looking good. I'm watching with great interest.
              Building one of these pizza ovens is a lot like building a house:-
              When you get the slab done you think to yourself.... yep that looks about right
              Then you get the walls up the thing suddenly looks....well, thats looking a bit bigger than I first thought....
              Then you get the roof on you suddenly discover Heh...... thats Bloody huge!!
              Mate I'll be watching ya built this one a 42' ovens quite big but a 48" is really big can't say I heard of one....perhaps I'll check the commercial builds
              regards dave
                Great work, I like the way you have your supports for the top slab. I think I will do something very similar as it looks very sturdy and easy to disassemble once the slab is set.
                Keep the photos coming.
                  Guys
                  Give you a great trick for the formwork....Use a battery drill and long chipboard screws.... can't knock the framework out of plumb like hammering nails in. Strong... you bet.....easy to pull your forms apart at the end
                  No need to drill them completly in so you can find the ends easy only danger is don't pour any concrete in the ends and don't tear you shorts the missus i'll be on you case.
                  Regards
                  Dave
                    Hi
                    Looks great! bet cha stoked with the results. One question though.... High Dome or Low Dome?
                    Regards Dave
                      Doug, you seem pretty serious about getting that 48 inch monster in service ASAP....Great progress and well designed
                      Looking good!
                      Lee B.
                      DFW area, Texas, USA
                        looking great Doug I love the thermo couplings for the floor it'll make things easier for you.
                          Doug,
                          Fine-looking build! Anxious to see how the transition proceeds. Must be nice to have an assistant!
                          John
                            Doug,
                            That was a great idea on trimming the arch bricks. Wish I would have done that as it would have made the transition easier to deal with!
                            Follow my build Chris' WFO
                              Hi Doug,
                              I've been reading your thread with great interest. Your oven looks to be coming along beautifully...great work !!.
                              Firstly, I was wondering where you got your supplies from and secondly, how do you know at what angles to make the inside cuts of the arch where the chains of 1/2 bricks connect to?
                              Regards,
                              Bruno
                              Regards,
                              Bruno
                              http://www.fornobravo.com/forum/f35/...hen-18538.html
