Need help with the mortar mix - Forno Bravo Forum: The Wood-Fired Oven Community
  • Need help with the mortar mix
    Hi all - Ive just started building the dome on my oven and I need help with the mortar mix.
    I have purchased A600 Chinese Cement from Field Furnace Refractories (wetherall park sydney).
    Is this a premix or do need to add sand etc.?
    What are the ratios?
    I have also read alot about adding fire clay, is this necessary in this cement?
    Heath
    Re: Need help with the mortar mix
    FFR should be able to help you, call Andrew or Alan.
      Hi Heath and welcome aboard.
      I personally wouldn't use any of these products and stick with the poor man's mortar for several reasons. It is easy to make, cheap and seems to out perform all these other refractory products.
      Cheers,
      Neillís Pompeiii #1
      Neillís kitchen underway
        Cheers,
        I agree! I've built a few and especially those ovens with a lot of reinforced thermal mass on top, things are not going to move too far, only as far as a quality fire brick will allow! I know with the method I use, very little of the mortar actually sees flame and has no way of getting into the oven.
        Boom Shanker! (Neil - The Young Ones)
          montiesridge
          How did you go?....What was the answer from Allan/Andrew I would like to know myself
          Regards Dave
            I would also like to knwo what to mix the A600 with...?
            Anyone find out the answer? IS it just water is sand required?
              montiesridge
              Regards Dave
              Actually Dave, Andrew has left FFR sometime ago.
                Vermiculite. Various ratios, for different strengths.
                  Vermiculite in the mortar??
                  Won't this make it way too coarse?
                    Hi All,
                    1 part Portland cement
                    3 parts sand
                    1 part lime
                    1 part fireclay
                    Thanks,
                    Heidi FB
                      Hi All,
                      3 parts sand
                      1 part lime
                      1 part fireclay
                      Thanks,
                      Heidi FB
                        Heath
                        just go with the poor mans morter i was a little concerned before I started however it does a great job. Ensure you use riversand not brickies sand.
                        Leigh
                          Has fireclay another name in New Zealand And Australia please? I can't find a seller in NZ. Thanks
                            Hi not sure if it called the same in NZ I had to source mine from a company that makes clay bricks locally.
                              I will try Huntly tomorrow. Thanks.
