My 1st build - Forno Bravo Forum: The Wood-Fired Oven Community
My 1st build
  • My 1st build
    G'day everyone
    Over the last year and a half I have read this forum and learnt much from everyones opinions/advise.
    I started building a 1 metre internal size dome wfo in the first week of December 2010. My aim was to cook Christmas dinner in the wfo and I will achieve that this year in 2011, 12 months latter than planned. If I'm honest 3 1/2 weeks to complete a build while working was slightly optimistic! The first pizza was cooked in the oven back in end of January 2011.
    The oven is nearly finished. It needs the final texture coat and some paint on the dome. The wfo floor is currently about 1.7 metres above the ground as I haven't built the deck in our pergola yet. To many good ideas, and not enough hours in a day!
    Thank you for all the great advise and to a mate in Adelaide who has also built a wfo.
    Cheers Andrew
    Re: My 1st build
    More photos....
      Re: My 1st build
      And more photos....
        Re: My 1st build
        Another batch of photos.
          Re: My 1st build
          Getting close to the 1st pizza
            Re: My 1st build
            1st pizza
              Re: My 1st build
              Excellent work Andrew, looks absolutely fantastic.. excellent attention to detail. How has it been so far with the small chimney? any drawing issues?
              Such a relief getting that first pizza cooked isnt it! something I wont forget..
                Re: My 1st build
                The chimney is 150mm in diameter and 2.3 metres tall. It also has a 200mm offset to help it clear the pergola roof. The first 20 minutes or so after lighting i get a bit of smoke out the front. Once the dome starts to warm up there are no issues.
                What size flue did you put on your oven?
                  Re: My 1st build
                  My oven is a 36inch with a 8inch flue.. (insulated with a 10inch over the top..).
                  so.. 200mm diameter..
                  What I find helps alot is make yourself a blast door, or use wood board, so that only 50-100mm is exposed at the bottom for air to come in. I find this accelerates the wood burning and stops smoke coming out the front. Helps avoid ugly black smoke stains on the front too!
                    Re: My 1st build
                    Re the smoke out the front on light up - the 'outer' door has reduced smoke to virtually nil on start up.............
                    U Dont Have 2 Have a Long Neck 2B1
                      Re: My 1st build
                      Do a search on the forum for blast doors.
                        Re: My 1st build
                        Yep spot on goose. Works so well doesnt it!
