Pizza door design - Forno Bravo Forum: The Wood-Fired Oven Community
Pizza door design
  • Pizza door design
    A while ago there was a post with photos of a door design, multi skin with insulation. I have been unable to relocate it when searching. Does anyone remember the link? and is there an easy way of searching this site for information? (maybe I am doing something wrong!!!)
    Craig
    "All I ask is the chance to prove that money can't make me happy"
    Spike Milligan
    "It is only impossible if you stop and think about it"
    The Pirate Captain
    Re: Pizza door design
    I'm not aware of a link to doors, sounds like a good idea though. Here is the one I built. .062 aluminum and a bucket of pop rivets. It's filled w/ loose vermiculite.
    PhotoPlog - Enclosure
      Hi Craig,
      here is the removable insulated door that I made for my oven and the cast aluminium doors are in my build thread.
      Cheers.
      Neillís Pompeiii #1
      Neillís kitchen underway
        These are my two oven doors
        Lee B.
        DFW area, Texas, USA
          Have a look here, it might help you out!
          Cheers!
          http://www.fornobravo.com/forum/f28/...ign-17110.html
          Boom Shanker! (Neil - The Young Ones)
            Thanks chaps.
            Some great designs to work with. Not sure if any of these are the ones I had seen before, but it will certainly give my son (the metalworker) food for thought.
            I seem to recall that the one I had seen used the vermiculite/cement mix as an insulating layer in the door. Does this sound feasable?
            I was also thinking of using any left over fireblanket as an insulating layer.
            Craig
            Spike Milligan
            The Pirate Captain
              Craig,
              just be aware of metal doors and materials that will convect your heat out of the oven through the materials used in your door construction. My cast aluminium doors are not insulated (although they were and may still get the insulation), c0nvect heat and cool the oven much quicker than the wood. superwool and expanded mesh.
              Neillís Pompeiii #1
                Try to make your door as light as possible. Lifting a heavy (and hot) door in and out can be a pain.
                  The weight issue cannot be overstated! My insulated door weighs 35 pounds and feels much heavier than that. Next time.....
                  Lee B.
                    WOW
                    I am glad I started this thread. It has changed my door construction ideas. Lots to think about.
                    Leaning away from solid steel now to perhaps insulated wood door (perhaps Jarrah or RedGum) as I am keen to keep as much heat in oven overnight etc, to make multiple uses viable from the initial fire. Particularly in winter in the Adelaide Hills. Gets a bit cold.
                    Would an inner steel panel sandwiched to timber door with a thick layer of insulation in between work well?
                    Craig
                    Spike Milligan
                    The Pirate Captain
                      Gudday
                      This door is insulated... hebel and wood...it might not be what you ask for to start with but its effective, easy to construct and cheap
                      Regards Dave
                        I've read through this thread and all the links inside it - great tips on doors. I need to make two for my build pretty soon, Just wondering where to find (in Brisbane) these key materials for planning/making an oven door:
                        Temperature guage/probe
                        glass rope
                        Fire rated silicon (tried looking in Bunnings but couldnt see - any hints on brand name?)
                        Door handles with the spring style handle
                        Also does anyone have any tips for places to pick up some of this stuff on the cheap?
                        Hebel or Cal Sil board offcuts
                        Steel offcuts, expanded mesh, aluminium sheet (bunnings does sell some) etc
                        Cheers.
                          Gudday
                          sorry edited this because I'd forgot i had posted the same before....should attempt a repy on a mobil phone I suppose
                            Gudday
                            The store is closed
                            This might help ( hope the links in date ) utherwise check out Relience brands on the net for a pizza oven probe
                            Regards Dave
                              Hi Craig,
                              Thank you for the post! I love how you all come together to help one another out. We would not recommend using a wood door sandwiched with a steel panel. We suggest that you keep a clearance of at least 6" from the oven opening to combustibles. Even with the steel panel in place you have not reached you clearance. We have on our website a insulated door that is a great design. Hopefully your son can fabricate a door to help you.
                              Thank you,
                              Forno Bravo
