Wood fired oven corner build in Grafton NSW
  • #46
    Re: Wood fired oven corner build in Grafton NSW
    Beautiful job on the inner arch and transition to the dome.
    Chip
    Chip
    • #47
      thanks mate, all down hill now right? lol
      My build. http://www.fornobravo.com/forum/f51/...ton-18665.html
      • #48
        Good feeling to clear the arch. Much easier go until you get closer to the plug. Be patient then, take your time with your cuts. Finish out with same quality you have done so far. Good luck.
        • #49
          Actualy the brick cutting gets a little more tricky at this point and higher. be careful on matching vertical seams as the bricks will need to become much smaller.
          Chip
          Chip
          • #50
            Chip
            I thought it was to good to be true and have noticed the inverted "v" in the vertical seems getting bigger
            • #51
              It looks like you are tapering the bricks, are you beveling too? Like MrC says, the bricks do get smaller in this area.
              • #52
                Ive tapered one side of the bricks right from the start and for this coase and the last ive beveled both sides.
                Heres how Im cutting my bricks to get the angles, crude I know but it works.
                • #53
                  Chip
                  thanks it finally sunk in ,cutting the bricks smaller! that helps alot,
                  • #54
                    Does not matter if how you get your bevel, if it works that is all that matters. Based on what I have seen from your pics your process must be working just great. Nice tight joints. Sounds like you got the idea of smaller bricks but here is a visual for you.
                    • #55
                      Hi wayne
                      That is one really nice build. you doing a great job. Post lots of photos as i'm about 4 weeks behind you on course 3.
                      I might need to view those photos as you get higher.
                      Cheers Colin
                      • #56
                        Will do Colin and i'll take some from the inside next coase.
                        Three coases to go
                        I feel like I just got the hang of things and Im almost finnished the dome.
                        • #57
                          Nice Wayne
                          Your just working it out and I'm yet to work it out . Did figure out to get rid of the inverted V on my jig and I guess everyone's jig I need to mark top and bottom and cut brick with bottom up.
                          Had some issues keeping mortar to around 3mm but have figured that out. I’m attempting to keep brick to brick inside the oven with no visible mortar. Not quite achieving it but very close think it have that sussed too.
                          Be interested in your last 3courses. Especially angle measurements if you are able of tilt and taper.
                          Cheers Colin
                          • #58
                            You two guys have got a bit more precision to your fit than me
                            Damon
                            Build #1
                            Build #2 (Current)
                            • #59
                              Originally posted by oasiscdm View Post
                              Nice Wayne
                              Had some issues keeping mortar to around 3mm but have figured that out. I?m attempting to keep brick to brick inside the oven with no visible mortar. Not quite achieving it but very close think it have that sussed too.
                              I hav'nt been as pricise as you(you can tell from my jig) and im betting it will show in the end result.
                              I have been keeping my mortar joins small as well, but with no specific messurement in mind and I am trying to keep the mortar to a bare minimum on the in side.
                              • #60
                                OK there's three coases to go now..
