My Precast build - Forno Bravo Forum: The Wood-Fired Oven Community
My Precast build
  • My Precast build
    Hi All
    Special thanks to John the oven man for his help in getting started in the build
    I decided to craft my own oven from the info from Forno Bravo and what i have learnt reading these forums here, thanks to all the good posts
    I have the oven finished now i have been cooking pizza's roasts lasagna bread etc since august 2012! so six months of bliss!
    OK onto the build
    my first requirement was to be that it needs to be mobile if ever we move house i am taking this thing with me, and also if i want to go make pizza
    at someone else's party i can!
    so the first 4 pictures are the frame design the trolley has a removable top the angle iron frame lifts out of it to allow me to put the oven on a trailer etc
    i hope the pictures attach
    Re: My Precast build
    Now
    i have cut and inserted the insulation board its about 30mm thick
    and put some mortar around the edges between the angle frame to lock them in place
    the supports underneath are @ 300 centres
    however if i was to do this again i would also lay either cement sheet or thin galvanized sheet under the insulation board for added security
      You should double your insulation.
        oven floor layout is 1050 mm inside diameter
        notice i have turn the floor tiles to be at 45 degree's layout so the tools don't catch on the floor bricks
        The mold was stuffed full of any rubbish i could find to save on sand,
        i must admit the design of my chimney works extremely well the face of the front, i can still put my hand on it is just warm even after 2 hours of operation
        i have seen people saying that they get burnt eyebrows etc from the heat coming out of the front!
        Back to the mold
        The face imitation brick was derived from cutting some weatherboards and using the rounded strip nailed to some chipboard i laid this out as best and rough as i could to imitate brick
        i cut some stainless chimney about 150 mm long then sniped all around and bent the tags to embed into the concrete as shown
        Sorry all i got excited at this point and forgot to take some pictures of the cement mixing stainless steel needle adding etc or the the final mold finished
        more to come still
          Yes i agree and that was the original plan,the supplier only had enough in stock for 1 layer
          however
          while the floor tiles are glowing red hot the under side is only just warm hardly noticeable so I am not loosing any heat really
          and that board is 30mm so inch and a quarter thick
            The sand mold was covered in wet news paper the cement layered on by troweling till the desired thickness was achieved i have varying thickness through out the oven to aid i hope in heat distribution,
            then the mold pulled off the front and the sand emptied out with all the rubbish etc and a work light used to warm the oven after 2 days of resting to help dry the oven out, i had used a piece of plaster board to make a temporary door to help keep the heat in while using the light.
              Ok the First FIRE
              slow low fire as shown in picture for about 8 to 10 hours
              then a bigger fire for another 10 Hours
              till the oven was at operating temp
              then i let it cool down and got it ready for some insulation only to be on top
                Insulation added i will use the oven like this for 6 months to dry it out then add the extra insulation and render see later pictures
                  Some food from the oven the first pizza just a garlic and cheese
                  first roast
                  first loaf
                  and some pizza burning away inside the oven
                  Next how to rig the oven so it can be transported and render
                    Now this oven needs to be mobile transporting it and keeping it tied down on a Ute or trailer is not going to be an easy task specially if you have a small accident this thing would go flying
                    so the design i come up with,
                    remove insulation
                    drill 4 holes through the steel frame and ceramic board close to the oven at = points for some all-thread rod
                    add chain to correct length to cross over at centre point and weld at that point
                    then weld off the nuts on the all-thread to stop them coming undone the underside nuts are then free to be tightened to a FIRM hold on the oven also notice how i have stripped some insulation down and tucked it under the chain links so they don't come into contact with the oven
                    The reason for using chain
                    it will have some give for expansion when the oven heats up and it will not transfer heat along the links very easily and the test confirmed i lost no heat down through the frame from the system at last firing
                    Little Bit more to come
                      time to put insulation back on
                      then add double insulation and start chicken wire and render,stucco,
                      The door was made at a friends fabrication shop and had the sheet metal guys fold it for me i went to Bunnings got a broom stick handle and cut it as required, some stainless steel electrodes,some pieces to make handle extensions and welded it all up to make a door.
                      I may 1 day insulate the door, i have some board left over.
                      you may also notice a crack in the picture of the door dead center this was my fault not a casting fault. YOU have to take the chimney out before pushing it under the veranda in the dark and wonder what the hell belted you so hard on the HEAD!!!!!
                      so now the oven itself is finished just a little work to do on the frame and base to finish it off
                      please don't pick on my render effort it was my first attempt, i was going to finish it better then it is but due to other circumstances i did not get a chance to finish it off properly.
                        So all told the build took me
                        4 days to first fire this includes the frame
                        and another day to do the chains and render
                        so here are some pictures of the spoils from last night
                        and a picture for anyone that is still in the cold weather
                        So thanks to all who shared designs, ideas, know how,
                        without Forno Bravo's help and plans this may never have happened
                          great build and the pizza's look great too! but they will turn out better if you dont use the trays and just cook them straight on the oven floor
                          My build. http://www.fornobravo.com/forum/f51/...ton-18665.html
                            As of my attempts to go on the floor have resulted in burnt bottom raw top
                            I'm wondering what temperatures you guys have on the floor and on the dome
                            I can do it buy cooking three quarters of the time on the plate and then removing the pizza and dropping it directly on the floor
                            But my daughter see's any black she will say I burnt it
                              Move the fire off to the side and let the oven neutralize for about 10-30 minutes. and the floor will cool a bit away from the fire, but I fear that if you are not getting the dome heat you desire your oven may still be a little damp.
                              Does the dome clear? if it does not your dome is not hot enough.
                              I typicaly see dome temps at 800-950 and floor similar. I do not see any live flames licking over the dome above the pizza just hot coals on the side in your photos, it is hard not to cook the top with live flames leaping half way across the dome, You can get some additional crisping by lifting the pizza to the top of the dome at the end of the cook to final it.
                              Chip
                              Chip
