Metal Fabrication Adelaide Area - Forno Bravo Forum: The Wood-Fired Oven Community
  • Metal Fabrication Adelaide Area
    Hi, I would like to track down a metal fabricator in the Adelaide area (preferably the Hills) to make the front opening arch support. Do any of you other Adelaidians know a good one? Also What is Poorman's mortar?
    Re: Metal Fabrication Adelaide Area
    Billkidd,
    I believe they gang is talking about what us yanks call Homebrew
    3:1:1:1 sand, fireclay, lime, portland cement. It has been used quite a bit by builders in this forum. I used it in my build. Is it a topic of debate on the forum, just search for Homebrew and you get the answer.
      An arch is self supporting, having steel support anything in a wood oven is fraught with danger.
        Thanks Al.
          Thanks Russell, I'll have a look.
            Hi billkidd,
            to me provided that you do it properly with room for the metal arch support to expand at a different rate than the surrounding refractory brickwork, I see no problems at all as I put in an arch supporting my oven, not to support the arch bricks, but to hinge the cast aluminium doors.
            I have pulled the pictures from my build or you can check them out at:
            the angle iron supports are a loose fit in a wider groove cut into the dome bricks and can move independently without problems.
            Where abouts in the Adelaide hills are you located?
            Almost any handy person with a hammer and welder can make one similar.
            Cheers.
            Neillís Pompeiii #1
            Neillís kitchen underway
              dsfgfsdgfdhgdfg dsfdsgfsd
              Fabrication Melbourne
