I know that the work is done now, but if anyone runs into issues with an invisible fence wire again, there is a simpler way...you can order a repair kit with the 14 gauge Polyethylene wire, wire nuts, and waterproof splice tubes from my website. Strip the ends of the replacement section of wire and the adjoining wire on each side of the break...twist together in "pigtail" fashion, screw on the wire nut, tie an overhand knot about six inches above the connection, then plunge each connection into the splice tube (jelly filled) and snap the top closed. This is how the original spices in the system perimeter should have been done and is the preferred repair method of professional pet containment companies. The kits can be found here at fencebylance.com/repair.html Hope this is useful to someone, better yet, hope no wires get cut!
Lance Sinkowski
