my summer project begins.
  • waikato pizza
    Re: my summer project begins.
    I have been pretty busy of late, hence I haven't posted for a while. Here are some photos to show progress. I decided to use the "I" shaped blockwork. THis really makes alot of sense. It mean your timber storage is not so deep you cannot see the back and I do not fancy crawling in with my ample rump on display to guests should I need to get a little extra firewood. It also bade framing for the concrete pour easier as there is something to fix to everywhere you need.
    Now that I am up to laying the hearth bricks, any words of wisdom or warning would be appreciated.
    All things taken into consideration I am pretty happy with the way things came out, apart from some of the top surface of the concrete was destroyed by over watering whilst the concrete was curing, but as I am looking to grind the concrete this really doesn't matter too much.
    Look forward to the replies from you all - Cheers Andy
  • brickie in oz
    Originally posted by waikato pizza
    Lots of people mention FB board across this site, but what is it? Hardie board is a concrete product so I know it cant be that, any help on a product name? This question is pretty much for australasia as lots of things have different names over here - Brickie in Oz? any answers
    Its really called calcium silicate board.
  • waikato pizza
  • Laku
    Cement will only take temp up to 600c before its start breaking down.
    Actually Cement starts to break at about 300 c.
    "Concrete exposed to up to 100 ?C is normally considered as healthy. The parts of a concrete structure that is exposed to temperatures above approximately 300 ?C (dependent of water/cement ratio) will most likely get a pink color. Over approximately 600 ?C the concrete will turn light grey, and over approximately 1000 ?C it turns yellow-brown.[4] One rule of thumb is to consider all pink colored concrete as damaged that should be removed."
    Concrete degradation
    Gudday
    The Aerated renforced panel you talk about is that "hebel". Yes I have hebel as the insulation under my oven. I have not had any problems with it but I think because I have 75mm 3 in of hearth bricks the heat has time to temper before it gets to the hebel. Cement will only take temp up to 600c before its start breaking down. So for this reason I always recommend anyone using hebel use a layer of FB board or "perlcrete" to protect it from the higher temps.
    Regards Dave
  • waikato pizza
    Well, I have had a couple of sessions available - the block work is completed - gonna be tight, but I think Christmas (maybe New Year) Pizza is possible.
    Read a thread about changing the "perimeter" hearth design. Seems to make sense and so I made an "I" shaped block work base. I reckon apart from having to make a few extra timber cuts, this design should support through the center of the oven. I reckon this will prevent sagging and prolong the life of the oven. Still only time can tell on this!
    Anything I need to be aware of before pouring the slab - I plan on sinking precast aerated reinforced panel into the center, below where the oven will be.
    Thoughts from anyone, gratefully received as throughout the project so far I have found masses of information. Thanks to all that contribute.
  • waikato pizza
    Thankfully, the are to the right is going to be a flight of stairs, hopefully this summer. Then I have a second lawn, which has a similar rake to the lawn where the oven is situated. BTW - I did not realise how much of a slope the lawn had until I laid the foundation slab and could see what level looks like by comparison. I was quite shocked!! And I originally thought it was the beer!! lol
    Gudday
    Your yards got a bit of a fall hasn't it ......glad its you mowing it
    Regards Dave
  • waikato pizza
    Well I finally got some time to place some blocks - well its a start!!
  • Laurentius
    Ok, now I get it.
  • waikato pizza
    Just supporting a timber that helps seal the concrete form. Due to the nature of the site, I also incorporated some bricks and aggregate to stabilize things. The brick is far from structural. Once the slab has set I intend to screed the side and pretty things up. Hope this makes sense
  • Laurentius
    Al,
    Thats not a skate board ramp! What is the brick holding up?
  • brickie in oz
    I'd have to be a complete galar to get it that wrong
    Some do believe it or not.....
  • waikato pizza
  • brickie in oz
    OK, got it, the land has a fall of 180mm.....
