Re: 48" brick oven from Melbourne
This is where i got up to in last few days, I've been working my ?ss of to get the dome done, and now i need to concentrate on front arch and chimney.
I've got few questions should i put 2 layer of ceramic blanket straight on the dome or i should add extra mass, like a layer 50mm of shiracast Cement to my dome first and then blanket and than another 50 or 100mm Shiracast cement and sand?
Can i leave my dome exposed to any rain now or should be covered?
Any advice how can i finish the front arch and chimney, would be appreciated?
The angle got so bad on the 5th course of the dome,it come to a point where i got worried that everything will collapse bit it didn't.
Then i pack some sand to get the dome closed.
Can i shave some bricks with angle grinder inside the dome there is some bricks which are sticking out a little to make a look nice or just ignore?
Cheers Dario
Do you have permission from your local council to build so close to your boundary fence? Where I live we are required to build 1.5 m away from any boundary fence, otherwise a complaining neighbour could force you to dismantle all your hard work.
In the #4 photo of your rebuild, it may be an optical illusion to me, but are the solders leaning inward somewhat? If so, are you planning a headstart on the horizontal travel of the Dome? Looking Good!
Free fuel would be nice.
Cheers
well done Dario you wont regret it.
Originally posted by cobblerdave View PostG'day Davids
The 1.5 rule is pretty much Australia wide.
Post 31 and pic no 1 what do you think the ruling is for a naked flame from a petrol tanker would be:
With such a large oven Dario, perhaps you could drill a hole in the fence, rig up a line and "borrow" some of your neighbours fuel.Last edited by david s; 04-24-2014, 04:49 PM.
Originally posted by david s View PostDo you have permission from your local council to build so close to your boundary fence? Where I live we are required to build 1.5 m away from any boundary fence, otherwise a complaining neighbour could force you to dismantle all your hard work.
Dario,
Atta boy, now your talking. Be sure to ask away with any questions, they are much easier to fix than after the fact.
Ahh Much better. Well done. Now you are on your way to a beautiful...and efficient! Wood Fired Oven. Sleep well.
Regards,
AT
Thank you for all your input for convincing me to pull everything down as i did today, and i am starting allover again this morning.
It was hart breaking to destroy all my hard work i have done.
I cleaned all the brick and will use it today, didn't cost me anything more, just a day full of work. hehehe
Just before going to bed i will like to share few pictures with you guys what i have done today to guide me and support me during my build.
Thank you once again.
These sources alluded me but I sussed them out and that allowed me to build the oven I did. Meeting my requirements to the letter and I sourced materials at go I'd process. Do it right and you won't regret it do it wrong and you will regret not listening.
I pulled mine down twice as it wasn't right.Don't settler on second best.Last edited by oasiscdm; 04-24-2014, 06:59 AM.
I agree Russell.
Dario as I said Pm me and I will contact you and let you know all my sources for materials
Acrigg,
The heat sink problem would still exist since the dome bricks are sitting on the sand too.
Dario,
I second and third that the rebuild will be much faster than the original build and in the long run the better oven performance will far outweigh the setback.
Is it not possible just to pull up your fire brick layer and cut the board to fit?
How much of the dome have you built?
Dario
PM me and I will let you know where to obtain. I live in werribee and work in the hillside area.there is a place in sunshine west.
