Re: 100 cm oven building in Romania
that was the first thing that popped into my head.....the corner or "point" in front of the oven. Definitely don't want that.
That's a picture with the foundation frame. I used 10mm rebar for contour and wire mesh for inside. I placed the iron reinforcements 5 cm inside the margins and under the future surface of the foundation. I intend to cast it in 2 weeks when I'm back from holiday (Italy again ) where I'll do some more research.
Originally posted by byzonoo View PostI'll make the oven chamber 100 cm in diameter and I left 20 cm for the wall thickness.
Do you think that's enough?
Florin
Two things, I would not want that point in my chest when working the oven.
It may be that your image is to large to upload. You may need to use a lower resolution setting on your camera before taking them or use a program to lower the resolution. I find 1024x768 more than detailed enough for the purpose of this forum.
I aleady dug the hole for the foundation and made the rebar frame but I don't know why I can't upload the photo on the forum. ("upload failed" message)
I'm thinking a blanket and stucco. I'm open to any suggestions and advice, I don't know how it would be best.
Florin,
Are you going to insulate with a blanket or vermiculite? Also, covered with an enclosure or stucco?
So I decided to build my own WFO. As I mentioned I'm from Romania, there are not plenty of those around but I was in Italy a few times and I loved the taste of fresh "Pizza al forno legna".
Since the plans that I found on the net were for much bigger ovens than I needed, I decided to make my own plans according to my own needs and space available. I'll make the oven chamber 100 cm in diameter and I left 20 cm for the wall thickness.
Do you think that's enough? Any thoughts on the plans and the measurements? I can make some plans with imperial units too if needed.
FlorinTags: None
