Re: Raffy's WFO Build
Hi Raffy,,
Looks good so far, Just one question, I cant see in the pic, do you have your front opening supported with angle Iron ? Or do you plan on suporting it another way ?
Cheers
Mark
Thanks, Mark. I'll definitely wear latex gloves when handling cement. Today, I just finished piecing together a rudimentary stand. We'll be doing the final finishing of the stand tomorrow then its off to assembling the hearth slab frame. I won't be able to pour the slab til Wednesday or Thursday. It all depends on our progress.5 Photos
Hi Raffy,
I believe its the lime in the concrete that destroys your hands, I got a box of latex gloves, even when I was laying the bricks I wore them,,, There is also a product called liquid gloves if you can find it,, You rub it on your hands and it helps a lot keeping your hands from getting destroyed... Good luck and keep going
Mark
Thanks for that tip, Neil. I'll be sure to wet the surface from now til 7 days after. It's summer here right now. As it is, it's already 39 degrees Celsius indoors I can only imagine how hot it can get with direct sunlight. Very sound advice from you. I would never have thought of doing that.
Thanks again for your help. I'll be sure to keep it hydrated.
Regards,
RaffyLast edited by Raffy; 03-06-2010, 08:03 PM.
"Yup I will put gravel then a plastic sheet so the ground wont wick away the water from the slab."
You don't really need the plastic. (Which is going to get holes in it anyway). Simply soak down your sugrade - the gravel layer - before you pour. After the initial set, as soon as it will take it, start flooding the concrete gently with water. Keep surface continuously wet for a minimum of 7 days. Cover it with burlap sacks or old towels or such and then your plastic sheet.
Thanks very much, Mark. Those are certainly words of encouragement for me and I value it very much. Here are the pics of the dry concrete. I definitely was not prepared for how much the cement mixture would dry my skin. My hands are like sand paper now. I guess I'll wear gloves the next time I mix up a batch.
I put my hand print and my dog, Yogi's, paw print, in the wet concrete as well as some scribbling hehehe. It didn't come out the way I expected it to be and my penmanship leaves a lot to be desired. Hahaha! But at least it gave it that personal touch! Even our cat, curious as she was, left her mark during the evening while I was asleep.
I'm going to let it cure more over Sunday and then I'll start stacking the blocks and hopefully get the frame of the hearth slab done by Monday.
It's such fulfilling work I'm thinking about my second build already hahaha. Just kidding.
Raffy5 PhotosLast edited by Raffy; 03-06-2010, 04:34 PM.
If you keep moving this fast you'll be done in no time at all
Good Luck
Cheers
Mark
Hi All,
I just poured the concrete but its too dark to take pictures of it now. I'll post them first thing tomorrow. It's a great feeling to have laid the foundation down. For the meantime here are pics before the concrete was poured.
Regards,
Raffy3 Photos
Good start raffy.... Are you going to put some gravel under your foundation ??
Hi everyone,
I have officially started with my oven. I have broken ground and have started tilling the soil and clearing debris. I'm so excited and I can already smell the pizzas and roasts. I'll post some pictures soon!
your welcome raffy,,
I am also friends with john on facebook.. Here is my facebook adress Login | Facebook
send me an invite,,, i have pics of my build... Also Forno Bravo is on facebook....
Thanks, Mark! We're friends on facebook already. Me and John I mean. I have seen his build. Quite interesting. He can most likely help me with finding materials although he is from a different region here.Last edited by Raffy; 02-12-2010, 10:17 PM.
hi raffy and welcome to the forum,,
here is a link to another phillipines build,, write to john,, great guy and im sure he would be happy to share info with you
Cheers
Mark
