Baking Calzone ('O Ripieno) at the Oven Mouth & 180°C Pizza Fritta Physics
  • ItalianGuysPizza
    • Nov 2026
    • 2
    Following up on our 4-Stage Topping & Moisture Matrix thread, we wanted to share the wood-fired oven thermodynamics of stuffed Neapolitan Calzone ('O Ripieno al Forno) and deep-fried Pizza Fritta (Il Battilocchio) from Chapters 15, 16, and 19 of our book ("Toppings and Desire: A Neapolitan Pizza Book of Ingredients, Science, and Stories"), developed with contributions from Maestro Enzo Coccia (La Notizia, Naples) and the Piccirillo family (Antica Friggitoria La Masardona dal 1945). Full technical guide & interactive formula scaler: https://italianguyspizza.com/pizza-fritta.html 1. The Wood-Fired Oven Mouth Zone ("Alla Bocca del Forno", 320°C–350°C): In a masonry wood-fired oven running at 485°C (900°F) near the fire, a folded calzone stuffed with buffalo ricotta, smoked provola, and cured pork has 3x the thermal mass of an open pizza. Launching it into the 485°C hot zone scorches the exterior dough before the center curd reaches its 60°C–65°C coalescence window. - Traditional Neapolitan Technique: Position the calzone near the threshold/mouth of the oven (alla bocca del forno, where floor and dome temperatures sit around 320°C–350°C / 610°F–660°F) for 150–210 seconds, rotating continuously with the peel so radiant flame heat inflates the pocket evenly without rupturing the rim seal. - The "Cappotto" (Overcoat) Trick: Veiling the top arch of the calzone with 20g of crushed San Marzano tomato and a thread of EVOO provides evaporative surface cooling that prevents the upper dough arch from scorching. 2. The Hydraulic Steam Barrier of 180°C Pizza Fritta: At La Masardona in Naples, the single-portion folded Battilocchio (stuffed with sheep's ricotta, smoked provola, San Marzano pulp, pork ciccioli, and cracked black pepper) is submerged in 180°C–185°C oil for 90–110 seconds. Because water flash-boils into steam with a 1,600x volume expansion, outward vapor pressure blocks oil entry while self-steaming the ricotta and provola inside an airtight dough shell. How do you manage floor temperature when switching from open Neapolitan rounds to stuffed calzones in your WFO?
