Re: Adelaide WFO Build
"Anyone have an opinion on adding lime to the mortar mix? I wasn't planning on using it, but wanted to make sure there's not some compelling reason for using it."
Gudday
Sounds like you using the poor mans mix...Portand cement lime firclay and sand? Yes the lime provides the long term, heat proof "glue" in the mix. The portland is there for the initial setting of the mix and as the heat destroys it the lime gets stronger. Use builders lime not quick lime or garden lime. You'll enjoy using this mortar its very different and feels more like mud than mortar to use but it works well.
You hav'nt mention a waterproof membrane yet.... if you havn't use a layer under your base use a bit of builders plastic before your cement slab otherwise your oven will always be damp and hard to use....
Regards Dave
Adelaide WFO Build
Niel, thinks for the heads up on thermal ceramics, will give them a go. Also, happy to take the clay off of your hands if it's surplus to requirements, PM me with your details and how much you want for it. The offer is much appreciated.
Doug, once again, thanks for the input. I just took the time to read through your build thread; definitely an inspiring read. Seems you are a true craftsman when it comes to building WFO's.
I think I will heed your advice and go for the thicker 'vermicrete', it's no issue to make it thicker, but obviously not something that can be changed very easily after it is built. Do you have a link to the thread about the floor thickness? I would like to read this before committing to laying mine.
The plans I am following are similar to yours, a bit from many sources and lots of great advice like this.
I started with Russel Jeavons book, and then found a few online resources such as Forno Bravo. The basic design is still true to Russels book, I'm using fire bricks for the hearth, and whilst I had originally collected red clay bricks for the dome (which all turned out to be too badly weathered to use), I then conceded to use Littlehampton clay pavers. Whilst trying to source the pavers locally I managed to find a builders merchant that had some second hand wire cut clay bricks from a brick oven that had been dismantled, so bought these instead.
The overall aim of the build is to build an outside kitchen area comprising of the WFO a BBQ and a pan / wok burner so that we can entertain and not have to cook in our (small) kitchen. the out-laws have a BBQ under their verandah and use it as an extension of their kitchen, it's very functional, and inspired me to want to create an outdoor kitchen for our house.
The inspiration for the WFO originally came from a trip to Sorento for my mates wedding. Whilst we was there we visited Pompeii and I was overawed with the place. A while later I stumbled across Russels book in a tourist information shop in Mclarenvale and the seed was truly planted.
I've thought about the build for ages, in fact I've had Russels book for about three years now. However, now there is an incentive to get it finished - My daughters first birthday. (Which is a little over 2 weeks away). Pizza is on the menu and we need a WFO to cook them in.
This evening I managed to finish off the kitchen base. Now I just need to fill the oven base with hardcore and then add some fill. Next up is to cast the kitchen work surface in concrete and the oven base in vermicrete. Hopefully I will get this done tomorrow afternoon / evening. Unfortunately I have to take a car for an engineers inspection which will waste most of the day.
Will keep you posted.
Mick.1 PhotoLast edited by vdubber; 02-16-2012, 05:39 AM.Leave a comment:
vdubber
Just around the corner from the Old red Brick Co is Thermal Ceramics. They have the vermiculite and are very reasonably priced.Also need to find a source for the vermiculite.
I also have 2 bags of fireclay that I got from Thermal Ceramics for my build if you need some.
Cheers.
NeillLeave a comment:
Thanks for the input Doug. Much appreciated. I am working to several different plans, trying to incorporate the best parts of each.
My subfloor is not suspended, it will be hardcore with compacted fill. I can lay down either concrete or insulation mix (or a combination of both) directly on top of this. My plan was to have a 4" subfloor with REOmesh and then lay the hearth bricks on top.
Would I need both concrete and insulation mix ( perlcrete / vermicrete) in this case? I have read that 'perlcrete' is used as a lightweight structural concrete alternative, so obviously no issue with its strength.
There seems to be a few differing opinions regarding the thermal mass of the floor; some say the larger the better, others don't think it makes too much difference. I decided to err on the side of caution and lay the bricks on their side (some even suggest two layers), it seemed like a good compromise. I think I will continue down this path, simply as I have already bought the bricks (plus it's an integral part of the design I have in mind).
Any comments / thoughts obviously very much appreciated.Leave a comment:
Good call. Just reading about this.
Does Perlite / vermiculite + cement in a 5:1 ratio sound right? Been reading a thread over at traditionaloven.com and that's what they seem to suggest.
I managed to get about half of the base done this evening but ran out of bricks. Will stop of at the old red brick co on the way home from work and pick up some more. Also need to find a source for the vermiculite. There's a hydro shop round the corner so I think I'll try there first.
I'm hoping to get the base finished tomorrow and the layer of insulation for the floor poured so that I can let it cure for a day before starting on the rest.
I did manage to find a local suppler for fire clay - A place called The Pug Mill not too far from me. They sell 20kg bags for about $60. Will pick some up tomorrow.
Anyhows, here's the progress. I did a bit more than this but lost the light to take pictures in. The BBQ goes in the gap between the gas bottle and the return at the end of the brick work. There will be a work are to each side of the BBQ. The wall will eventually go all the way across as the concrete work area will be cast in situ on top of it, it may also get extended upwards, but not 100% on that yet. The gas ring from the BBQ will also get recycled and be inset in the small work area to the right of the BBQ.
Slowly getting there. I can almost taste the pizza
1 PhotoLeave a comment:
Both.
I'm planning on a round enclosed base filled with hardcore and topped with a layer of concrete. On top of this I will add a base of fire bricks on their side (to increase the thermal mass) and then the oven on top of that. The base will be larger in diameter then the oven so that down the track I can enclose the oven if I feel the need.
The base will be enclosed simply so that I can get rid of a load of hardcore that I have laying about. There's till plenty of space left for wood storage under the food prep area so for me there is no need to have the base open, plus I like the look of a round base.
The base will also tie in with the work prep / BBQ area brickwork, which extends to the right.
Well at any rate that's the plan. Sometimes these things have a habit of going awry
Gudday
probably a silly question ...the ring of bricks...shape of the base? or position of oven?
regards DaveLeave a comment:
Picked up the rest of the bricks this morning. Seems like I was just in the nick of time. Bumped into another Forno Bravo member building a Pompeii oven - he'd bought the other half of the bricks that I'd bought. Whilst we were there yet another bloke arrived also wanting bricks for a brick oven. Seems like it's a popular pastime.
Apart from unloading the bricks did nothing else. Needed to let the slab dry out a bit. Will hopefully start laying bricks tomorrow arvo.
Here's some pics of the slab...3 PhotosLeave a comment:
Well done Mick you are certainly on your way now.
Keep the photos coming.Leave a comment:
Yet more progress pics (wish I could add more than 5 to a post
Ever wondered how many bricks a Range Rover can carry? I could have got more in but wasn't sure how the airbags would hold up. For future reference It'd do a tonne.
The brick in the pic are the soft reds for the base.
The second pic is the site foreman. Between him and the dog I now have brickies sand all over the garden.
Pics 3 and 4 - The slab is 100mm thick. Not sure it needs to be that thick but it seemed like a good round number. The REO is just stuff that I got from Bunnings.
Still got a heap more bricks to pick up which I will do in the morning. I also priced up a brick saw, which is an expensive bit of kit to hire. Think I might be using my grinder instead. I figure I've only really got the arch bricks to cut and maybe the very top of the dome. The rest I can do with a brick chisel.
Will keep you posted of the progress.
Mick.4 PhotosLeave a comment:
More progress pics...
The archway made up of flat-bar and square-bar plus the brick gauge I made from old scrap that I had lying about.5 PhotosLeave a comment:
Made some more progress on the oven.
Last weekend I decided to get prepared and do a bit of pre-work. I dug out the footings for the slab. I've opted to lay the slab below the level of my current pavers so that after the BBQ area is finished I can relay the pavers over the slab so that the concrete is hidden from view.
I also made up the hoop for the oven door. I bent up some flat bar and then welded some square bar around the inside to form the door jam. I was very tempted to make the door as well but decided to leave this until the oven doorway has been built.
After making the decision to get new bricks I went into a local builders supply as they advertised the Littlehampton pavers. After chatting with the owner I found out that they had both some second hand solid red clay bricks and also firebricks. At 60c for the reds and 3.50 for the fire bricks I bought enough reds to make the dome and flue and enough firebricks to do the floor laid on their side (for more thermal mass). Evidently the bricks came from a brick kiln out Salisbury way that recently closed down. A case of their loss my gain.
There a still quite a few fire bricks left and I am led to believe that they can also get more of the solid clay bricks as well.
Whilst I was there I also bought some reclaimed soft reds for the base as well as a tonne and half of premixed aggregate for the base and work counter and a tonne of bricksand for the brickwork.
After laying down some REOmesh I've spent this evening knocking up muck and pouring the slab. Unfortunately it was dark by the time I was finished so will have to get some snaps tomorrow but the end result is that the slab is down.
Now I just need to let it cure for a few days and I can start to build the base. I've got the cement mixer on hire for a week so the plan is to get it all done in this time.5 PhotosLeave a comment:
Managed to clear out the area. Here's some before and after pics.
First one shows the general area and the mock up of the original BBQ area I did using some old pavers and lumber. The second is a closeup. The third pic shows one of the things I found lurking in the woodpile.
and the last shows the cleared area with the sink relocated on the end.
The area without pavers laid is the approximate size of the kitchen, the wood oven obviously is on the left.
Hopefully next weekend I can get the slab down.
Mick.4 PhotosLast edited by vdubber; 01-08-2012, 06:44 AM.Leave a comment:
