Usefull WFO oven tools
    Re: Usefull WFO oven tools
    Gudday
    Found at Powers tingalpa QLD narrower heavier construction flatter ange to handle
    [ATTACH]34624[/ATTACH]
    That's exactly what I use Dave. Stomp on it and make the angle even flatter, reshape the leading edge so it is curved to fit the back of the oven and fit a longer handle.
    Gudday
    Davids ,I can never question you advice on many matters and now that will include "hot Hoes". The replacement handle will be of course be hardwood.
    Regards Dave
    Yes, I imagine that a hoe and softwood would be a poor combination.
    Gudday
    Regards Dave
  • brickie in oz
    Originally posted by david s
    A hot hoe can be difficult to manage.
    You just aint man enough for the job then....
    Originally posted by TropicalCoasting
    I would have thought a hoe or variation of a hoe would be ideal fro removing ash
    If using a hoe make sure it does not have a metal handle.
    no emoticons indicates dry humour?
    Gudday
  • Mistertoy
    I'll be going to bunning to look for that ash shovel... just what I need.
    I have been meaning to post the attached photos for a while. Made these tools based on tools I had seen on a few different internet sites - my Dad had some scrape tube laying around that was a perfect compression fit for attaching to the wooden handle and he did all the welding for me as well ... they work great and I actually use them all. The metal pizza peel is a bit big for rotating the pizza so I need to make another smaller one. Just need to find a place to store them all.
    The wooden peel is nice with a silky oak handle and cedar peel... some old timber scrapes my father in law had under his house !
    Brett
    like this?
    regards Dave
  • TropicalCoasting
    I use a similar shovel which is smaller, heavier gauge metal and more expensive. I found that the angle between the handle and the shovel mouth was to big for convenient use, it needs to be flatter. I had a look at the item you mentioned. You may be able to alter the angle by bending it. Also it will work better if you can curve the leading edge instead of it being flat so that it can fit against the curve of the dome perimeter, if you have a dome. You also need a longer handle.
    Gudday
    If it works.... its never dumb. Ive never thought about about removing ash that way before.... cuts down the amount of tool clutter now that I think about it that way.
    Regards Dave
  • Laurentius
    I use my pizza peel. Dumb me.
    Quote... I had a shovel from Bunnies that was very similar, the lift and angle of the handle made it useless at the back of the oven, which is where all the ash is.
    Gudday Al
    I have an aluminium flat rake wich I use to get the excess ash and hot coals from the back to the entrance..... this is were this will come in handy.
    regards dave
  • brickie in oz
  • oasiscdm
    Hi Dave
    Got Two. I don't have a mate to give a third one too
    The barcode came in useful, Thx For That!
