Re: Sourdough Starter
That must be one super radioactive spore.
Sourdough Starter
I have seen regional starters last from a year to several. Too many factors from the micro-biology side. Most important is keeping isolation from the local air. Just need to work quick in my mind to preserve. My last SF starter was overtaken after 4 years of keeping quick work and good hygiene. It only takes one spore to mess things up. My super sour Russian starter lasted 8 months.Leave a comment:
Jay,
I have some of my original starter that I froze. I started a new batch from scratch thinking it wouldn't matter until I read Laurentius' response. How do I bring the original back to life? I know there was a discussion a while back but I cannot locate it.
Thanks guy'sLast edited by Les; 02-28-2013, 10:46 AM.Leave a comment:
Hi Les!
While there are those who believe that sourdough strains can remain distinct, there seem to be relatively few documented cases of doing so iin close contact (i.e. a kitchen/facility) for an extended time. Being healthy is certainly an important criterion but there are those who question that is enough.
From my experience, with reasonably healthy starter, they should remain reasonably true for one to two years. Eventually mine have begun to merge characteristics. Whether keeping the starters robust would have kept them distinct longer??? is only speculative.
SF should have some chance of remaining relatively pure for it is so much more acidic that IF HEALTHY other yeasts and bacteria will not do well in it. However, its bacteria and yeast will (again from my experience) do well in less acidic environments so my first symptom was that my mild starter began to get more tart.
Eventually, however, my SF got more mild also. But I know it wasn't totally robust all the time so???
Even commercial SF sourdough bakeries refresh their starters in remote locations about every six months.
I think it is best to assume your starters will eventually merge at least partially. Good idea to freeze some of your existing starter before you begin a new one.
Good Luck!
JayLeave a comment:
I've read that one way of looking at it, was like white blood cells. When an invader from the flour or air enters the colony, they are attacked and destroyed. The local yeast must be fed, matured and multiply to form a colony and that takes time, which the host will not give them. If I had a renown bakery with satellite outlets, sending refreshed starter would be a good means of assuring consistency in our product.Leave a comment:
That's interesting. I thought your local yeast would eventually take over. Boudin's in San Francisco has 3 bakeries. They send starter to the two satellite locations every thirty days to maintain consistency.Leave a comment:
Some say never, as long as the colony are strong and healthy. I maintain 3(S.F, Ita., and a local) difference starter and feed them the same flour and they are distinct from each others, even the refreshment or doubling times are not the same.Leave a comment:
Sourdough Starter
If one were to get a starter from San Francisco, how long does it take for your local yeasts to take over? Not sure I could tell the difference but I'm curious.
Thanks...Tags: None
