I'm not sure in every case what is meant by "Ciment Fondu".
At the Wesco refractory, they called it 'fondu' and said I could use it for mortar. The bag I bought is labeled 'calcium aluminate cement'. There are instructions for accelerating cement on the bag.
As an aside, this refractory makes a castable refractory cement: The owner mentioned a simple castable refractory recipe that included this calcium aluminate cement plus aggregate and something else.
I see Australians use the term ciment fondu....Is it the same type of product?
Regardless of the down side of a quick set, I'm going to experiment with it and see if I can't use it in my home brew mortar (reducing the lime portion as necessary if it sets too fast). I'll be building the dome in 70F weather real soon, so I don't expect a set time that is too rapid like when it is hot outside.
What is your experience with calcium aluminate cements (in home brew mortar)?
