Removing fire bricks from hearth floor
  • Removing fire bricks from hearth floor
    A few of the fire bricks on the hearth floor spalled and have to be replaced. Does anyone know the best way to remove them?
    Fred Di Napoli
    Re: Removing fire bricks from hearth floor
    May I make a suggestion.
    If it were mine, I would drill a couple of holes in the offending bricks, insert a couple of 'dynabolts' (or even wall plugs with large headed screws), knock the bricks with a hammer and lift them out. If needed, because they are packed in really tight, I would also include a metal or wooden strip between the bolts/screws and use a jemmy/small crow bar to prise them up. Hitting the adjoining bricks will also help relieve them from their surrounds.
    Smashing then will only damage adjoining bricks and maybe make them tighter.
    In desperation, you might use a diamond saw on a small angle grinder and cut the offending bricks close to two edges, collapse the cut piece and lever out.
    Good luck.
    Neill
    Neill’s Pompeiii #1
    Neill’s kitchen underway
      Wire and liquid nails. Big glop on the face in 2 places and wire in each one. Lift out and viola - instant hole (after curing overnight that is.) I hate drilling in confined spaces.
      Follow my build Chris' WFO
        I am having the same problem - looking to replace most of the floor. Does anyone know why this happens ? Also , I am not sure my bricks were proper fire bricks, dont seem to hold heat to well. The dome also has quite a bit of spalling. do you think the dome can be sort of skim coated to prevent future deterioration ? If so , what should I use.
        Thanks ,
          I've pulled bricks a few times, using a couple of long drywall screws as picks (any thin, hard, pointy metal will do). Near the middle of the brick to remove, work the points in on opposite sides. Then push the picks outward; if you balance the inward force of the picks, the brick will be levered up. Reset the picks one at a time (so the brick doesn't drop), and repeat until you can grab it with your fingertips. It takes a couple of minutes the first time, but it gets quicker.
            We have to replace our entire floor do to determination over the last seven years. Can anyone give us some suggestions if you have done this. Thank you
