Another question
  • Les
    • Sep 2005
    • 2945
    Another question
    This should be an easy softball for someone to hit the 50k over the fence. My fist pizza's I had the hearth a little over damn hot. The bottoms tended to get burnt pretty easy. Yesterday I had the hearth down to 700 deg. The bottoms were fine but I was well over a 90 second pizza. So the question is; what is the optimal hearth temp for cooking pizza?
    Les...
  • asudavew
    • Jul 2007
    • 1880
    Re: Another question
    I couldn't tell you.
    You shooting the temps with a gun?
    I usually cook about 3-4 minute pies! I do know my hearth cools quickly when I cook.
    Are you spreading your fire and coals around, and letting the whole oven moderate after firing... then adding more wood to get some good flames while cooking>?
    Plus I felt like padding this 50k thing and finding out who has won!
    I'm hoping it's a noob.
    My thread:
    My costs:
    My pics:
    • egalecki
      • Mar 2008
      • 1049
      Les, my pies bake in 90 sec. or so- I spread my coals over the floor for a little while and then push them to the side. I do move the pie around a bit- as I need to turn it I move it a little. I haven't had the bottom burn. If it's getting to the point where the bottom looks good but the top doesn't, I usually pick it up on the peel and hold it up near the dome to broil it a bit...
      I don't know what the hearth temp is, though. I haven't made pizza since I got my IR thermometer. I'm guessing 800+, though. I let it get REALLY hot.
      How thick are your pies?
      Elizabeth
      • Les
        • Sep 2005
        • 2945
        Elizabeth,
        I spread the coals out after I go white. Last night I let it sit like that for about 10-15 minutes before the first pizza went in. I was a little hot. About 20 minute later I cooked the last one then shot the temp (Dave, it is with a gun) - 705 was the reading. The dough is about an 1/8 inch thick in the center. Next time you cook one, check the temp - I'd be curious what it is.
        Thanks,
        Les...
        • christo
          • Feb 2006
          • 913
          My oven floor reads about 750 degrees and the dome at that point is usually 850 to 900. The first pizza comes out superfast and usually one part of the side of the crust is black cause I'm not fast enough to manage it.
          That's usually a 90 second pie.... or less. After that I don't push the fire around much and the longer we cook the longer it takes to cook - which seems to mesh well with the intake of wine or beer.....
          Not sure why, exactly, but the pizzas seem to get better as the night goes on. It might also depend on how we layer the ingredients - I tend to put the onions or pine nuts on last as I want them to get as much heat as possible. cheese seems to be a good insulator (until hot stuff drips on your hand)
          We've had to crank up the fire for a second wave once and had ok results - we started cooking again when the fire was perhaps a little to big We rushed it for sure.
          I'd have a better answer if your wine bottles were not getting done on the bottom.
          Christo
          My oven progress -
          sigpic
          • egalecki
            • Mar 2008
            • 1049
            Wine bottles??? I don't recall seeing that anywhere in the recipes... sounds a bit.... crunchy.
            I saw this really cool cheese board recently, made from a wine bottle someone had made flat. How hot do you reckon the oven would have to get to do that??? And how do you keep it from sticking to the floor???
            Elizabeth
            • Les
              • Sep 2005
              • 2945
              Elisabeth,
              A quick google says it's around 2700 deg F. As far as sticking - I think that's way above corn meal
              Les...
              • Modthyrth
                • Mar 2008
                • 359
                Didn't christo slump a wine bottle in his oven?
                Nikki
                • gjbingham
                  • Sep 2007
                  • 2021
                  I like 850 degrees for pizza. Much hotter than that, I start having trouble with the tops and edges burning in the last few seconds before I pull the pizza out. I've had way more "failures" at 725 - 750 degrees compared to pizzas made above 800.
                  I've quit spreading the coals across the floor once the dome clears. I build my fires in the middle and make an effort to build the fire wider as I add wood. After about 45 minutes of heating, probably 80 percent of the floor is covered by fire.
                  Once I push it to the side, the floor is generally around 925ish degrees. I throw a couple of smaller logs/sticks on the fire and walk away for about 10 minutes. Usually, the floor is right at 850 by then. Rarely am I really ready to throw a pie in at the right time, but one or two are almost prepped.
                  If my floor gets down to 750 or below, I start adding wood to the fire and get the flames licking completely across the dome. About 3 -4 minutes later, the floor is back to 850 and I'm up and running again.
                  GJBingham
                  • PizzaPolice
                    • Sep 2006
                    • 338
                    Well I guess the Fire/Floor Temperature advice has been beaten to death.
                    Of course we all have different ovens. You'll find the optimum temperature for you when you find it. No sooner.
                    Ingredients are a HUGE factor when sticking food next to fire. If you want a 90 second pizza, it has to be just water, flour, salt and yeast or preferment. It has to be thin and sparsely dressed. If you add oil to the dough, that will accelerate the cooking and certainly cause it to burn. Too many topping or too much sauce will cause it to be mooshy and undercooked.
                    A lower temperature 700 to 800 will give you more time to play around with the pizza. This is my experience with my oven. The dynamics in smaller ovens may dramatically different.
                    Before long, your oven will be cranked up and you'll be sticking your hand in your oven for no more than TWO MISSISSIPPI. Then confidently toss in a pie and pull out a beauty.
                    Good Luck!
                    • egalecki
                      • Mar 2008
                      • 1049
                      Good point. I don't put any oil in my dough, so maybe that's the difference right there.
                      George, you and I have 36 inch domes, but I think Les's is a 42. I bet his fire doesn't get as spread out as ours- I find that after an hour and a half or so, I have fire all over the floor too. He must just be too tidy.
                      Elizabeth
                      • Les
                        • Sep 2005
                        • 2945
                        Elizabeth - you do wash your wood before you burn it? Thanks all - very helpfull!
                        Les...
                        • Bob C
                          • Apr 2005
                          • 95
                          I can cook my first 12 or so, usually 3 at a time, at a cook time of 3-5 minutes. At that point the temp drops and the restless natives are satisfied and i crank up the heat for round two. I will monitor temps next time around. But here in CT...thats not soon enough. On an average "WFO" evening, we bake 16-20 pizzas and a few stuffed breads with all of the leftover ingredients and lastly a few loaved of bread. Generally, this requires a mini refiring midway. Just in time to toss a few back.
                          Great pizza, a cold beer,a great cigar and great friends...my idea of a great time
