Re: Rain Saturated Oven
Stephen, thanks for the compliment.
To answer your questions:
Initially, I planned to only make a cover for the arch/entry that would wrap around the Duravent pipe. Not being 100% certain water was not getting in somewhere else, I decided to cove the whole thing...to just below the hearth slab level.
I measured and found that a 10' x 12' heavy duty tarp that is silver on on side , brown on the other would fit perfectly.....a little more eye appealing than the construction site "my roof is gone" blue tarps. I then measured how far up from the bottom of the hearth slab the Duravent is, cut a slit in the tarp as well a hole about 1" larger than the Duravent pipe. I then used self stick velcro strips on the two flaps created by slitting the tarp and placed self stick 1/2" rubber weather stripping around the underside edge of the hole that I cut out. Slide the tarp up from behind, around the pipe, and overlap the flaps.
Rather than bungee cords or tarp straps, I laced rope through the tarp eyelets allowing me to cinch it around my oven's "waist" to keep it from blowing off in high winds. only takes a minute to open in up and slide it off the back side. I'm pretty sure I will completely remove it for fall/winter/spring, the REALLY heavy rains are few and far between then.
It really is effective, but my oven "is what it is" for aesthetic reasons...I really don't want it covered with a tarp for 4-5 months a yr. Some how, some way, I am going to come up with a permanent roof system or cover that will still show off the mosaic and keep the torrential rains out. Thats the plan, and any construction/altering will have to wait until it cools down and is dryer during the winter.
RT
RT
