I am in the process of making my pizza oven and some of my firebricks are painted. Do I need to remove the paint before I begin mortaring? If I do, what is the best method to remove paint?
Re: Painted firebrick
Originally posted by LisaFrench View PostI am in the process of making my pizza oven and some of my firebricks are painted. Do I need to remove the paint before I begin mortaring? If I do, what is the best method to remove paint?Joe Watson " A year from now, you will wish that you had started today" My Build Album / My Build
I can only tell you that the bricks are very old, at least 75 years. People painted firebrick in the 70's because they thought that it looked better; what the heck! I think the paint is latex, it peels off a little when wet. They are painted brown, and from what I have read, the lead would be in the pigment. Wouldn't you use an iron oxide for paint brown?
Originally posted by LisaFrench View PostAlso, none of the brick faces in the oven are painted. Would it create a problem from extensive heat melting the paint...could the fumes still get inside the oven if the painted brick sides are mortared up?Joe Watson " A year from now, you will wish that you had started today" My Build Album / My Build
I feel that the best solution would be to diamond saw a slice of brick off and discard if you had to use them, otherwise use them in your base or landfill.
Just not worth having problems laterPrevention is better than cure, - do it right the first time!
Neill’s Pompeiii #1
Neill’s kitchen underway
My used bricks had a thin coat of old morar. I used the wet saw to trim it right down to the clean brick. Took a lot of time for little savings....Would not do it again.Lee B.
DFW area, Texas, USA
