And for pity's sake, if you can't do it yourself hire professionals!!!!
Now, all I have to do is hire a plumber to replace the stupid water tank some moron used a brass coupling on a steel connection to attach a plastic pipe to!!!
<insert smilie pulling out its hair here>
<insert brooding smilie here> You don't want to know how they put in the sink drain...Let's just say solder is not a good replacement for a simple 1 1/2 nut...
<insert smilie banging its head on a brick wall here>
