Closet remodel - my latest project.
  • christo
    • Feb 2006
    • 913
    It started out with replacing the carpet in the bedroom with hardwood flooring. My wife has allergies to my dog and cat..... We used 3/4 inch prefinished white oak and it turned out great.
    As part of the plan, we were to also remove the carpet in the closet and replace with hardwood. Simple after the bedroom.... Except my wife told me she hated the closet arrangment and the builders skimped on the materials and the paint was peeling from the masonite....
    So, we gutted the closet. everything was caulked to the walls - huge mess - When I took it apart, I think caulk was the major thing holding it together - there were huge gaps spanned with caulk.
    That behind us we patched the walls and tackled the floor. Then the task of what to do with the closet.... That's when I found out my better half has 70 pairs of shoes to design around....
    The pics attached are what we came up with.
    We used prefinished 3/4 maple plywood and prefinished iron on edging - works really well (trimming the edgiing is a really boring task...)
    Just finished up today!
    Christo
    My oven progress -
    sigpic
  • Dutchoven
    • Apr 2007
    • 931
    Re: Closet remodel - my latest project.
    Really great job, Christo! Hope your wife is very happy with it too!
    Best
    Dutch
    • Frances
      • Aug 2007
      • 2186
      Very nice! I wish I had one like that.
      ...on the other hand it makes me realise I haven't got nearly enough shoes!
      • Frances
        • Aug 2007
        • 2186
        And do you know why women like having so many shoes?
        I recently read this article which pointed out that its worth spending a lot on shoes, because even if you don't wear a particular pair often, you can keep them for years and years, and still fit into them even if you put on or loose weight, change shape, get pregnant, get old, whatever. Same goes for handbags and hats.
        Its completely logical when you think about it...
        • gjbingham
          • Sep 2007
          • 2021
          Great job Christo - looks more like a small room than a closet.
          GJBingham
          • PHISHINGPHANATIC
            • Aug 2009
            • 4
            Very impressive! I'm closing on a new (to me) home next month and the closets are awful. I'm certainly going to try to copy your work.
            • ThisOldGarageNJ
              • 1436
              Im noticing you didnt really leave to much space for more shoes ??? was that on purpose ??
              Mark
