What Do You Call This Thingy?
  • Archena
    • Apr 2007
    • 1214
    I know I've seen them, but I haven't got a clue as to what they're called. It's the metal shaft that is threaded in the interior so that it can act as a female to a bolt. The shaft is then glued into a hole in wood, so that a bolt can be threaded in and out multiple times without damaging the wood.
    Help?
    [/CENTER]
  • RTflorida
    • Jan 2007
    • 1446
    Re: What Do You Call This Thingy?
    I've never used glue in, the ones I have used in a few furniture building projects were simply called "threaded inserts" and "cross dowels". They are used for exactly what you describe. might want to try woodcraft.com, they sell alot woodworking hardware.
    RT
    • Archena
      • Apr 2007
      • 1214
      Thanks! I really appreciate it!
      [/CENTER]
      • ThisOldGarageNJ
        • 1436
        Kind of like a turnbuckle ?
        • Archena
          • Apr 2007
          • 1214
          Not quite. Here's a pic: Click image for larger version
          I want to build a table that will travel a lot. I need to be able to take the legs off and put them on often.
          [/CENTER]
          • ThisOldGarageNJ
            • 1436
            RT is correct, Threaded Inserts if his supplier doesnt have them try Rockler.com
            • Archena
              • Apr 2007
              • 1214
              Thanks, guys!
              [/CENTER]
