After my first question concering the placement of the perlite concrete slab (below the hearth slab or above), the advice I received forced me to do additional research. It seems that the advice to put the perlite concrete under the slab is more for Barrel Ovens or ovens that you want a lot of mass to store the heat energy that will be used for repeated bread baking.
Now for my next question, I will be building a wood fired oven! Now for the type. My time at home is limited for now (I get home only every other weekend). Purchasing an oven kit is not an option at this time. I will be getting help from my son for this build.
Due to the preceived difficulty of building a Dome oven I will be building the Barrel oven...unless I am told other wise from those of you that have the experience. Based upon this, would you all still recommend that the perlite concrete go ontop of the supporting concrete slab for the Barrel oven design?
I will be doing pizza's and bread and occasional roasts and other meats/meals.
'Cause I'm finally buying a house!!!!!
