Re: Oasis Rising
You mentioned building a door...So I thought I would show mine. I snatched an oven door off of an oven at the county dump. I cut it apart with an angle grinder then used the pieces to fabricate a door for my oven. I did this all Thanksgiving morning....well actually around noon since I went hunting for a couple hours that morning. I had some stainless sheet metal screws but came up kind of stumped when it was time to make handles. I found an unused hacksaw blade in the garage and used it for one of the handles then had to scramble around....and ended up using a piece of metal strapping that held the steel roofing material when I got it.
I had planned to reuse the insulation material in the oven, which I expected to be ceramic fiber. It was fiberglass. I packed it in there but don't think it provides near enough insulating power. Come summer, I will disassemble the door and fill it with vermiculite cement mix.
those Striped Bass sound awfully good right about now!
I may have to get another boat, I miss fresh sea food!
