I should probably have started a tread on the build earlier, but rather late than never I guess. I will also duplicate some of my initial pics just to keep the whole thing together.
The weekend I cast the insulation floor. You will see I only did the main circle. I planned to do the mouth as well, but in the final levelling of the floor which I did same time, I ended up going thicker than I planned & did not have enough vermiculite. Fortunately I read many comments re the option to insulate the mouth or not, so I rather finished the whole thing at the same time than to try to add another bit of vermiculite later.
In the pic you will see that I have only got the brick inner walls built and that the outer stone work is still coming. The pic with the floor cast is taken from the north west while the other two pics are from the south, so if you see 2 very dissimilar doors in the different pics, it is because there are 2 doors
The area below the oven is split by a dividing wall. The door under the oven mouth (the oak door) is for wood storage only (door to keep snakes out). The steel door is where I want to lock the batteries of my solar electricity away.
